Finding Error Bounds for Simpson's Method in Approximate Integration
2 replies · 2K views
Telemachus
Use the Simpson method to estimate [tex]\displaystyle\int_{0}^{1}\cos(x^2)dx[/tex] with an approximation error less than 0.001.
Well, I have a problem. Actually I'm looking for a bound for the error of approximate method integration by using Simpson's method.
I have to bring [tex]\displaystyle\int_{0}^{1}\cos(x^2)dx[/tex] with an error less than 0.001.
I started looking for the fourth order derivative, and got:
[tex]f^4(x)=48x^2\sin(x^2)-12\cos(x^2)+16x^4\cos(x^2)[/tex]
Now, I have to find a bound K for this derivative in the interval [0,1]. What I did do was watch for if they had maximum and minimum on the interval, then calculate the derivative of order five:
[tex]f^5(x)\in{[0,1]}\Rightarrow{f^5(x)=0\Longleftrightarrow{x=0}}[/tex]
From here I did was ask:
If [tex]f^5(x)\in{[0,1]}\Rightarrow{f^5(x)=0\Longleftrightarrow{x=0}}[/tex]
So here I know is that zero is a maximum or minimum. Then I wanted to look for on the concavity of the curve, and I thought the easiest thing would be to look at the sixth derivative, to know how it would behave the fourth derivative of the original function.
[tex]f^6(x)=720x^2\cos(x^2)-480x^4\sen(x^2)-64x^6\cos(x^2)+120\sen(x^2)[/tex]
The problem is that when evaluated
[tex]f^6(0)=120\sen(0^2)=0[/tex]
So, I get zero the derivative sixth, and I do not say whether it is concave upwards or downwards is concave.
What should I do? there may be a less cumbersome to work this, if so I would know.
Greetings.
You could just plot the function and see it hits a maximum on that interval at x=1. Alternately, you can use arguments like x2sin x2≤x2 to find an upper bound for the function. In these types of problems, it's usually not terribly important to find the actual maximum; an upper bound for the maximum is good enough.
I complicated it too much. Just by evaluating the 6th derivative in any other point of the interval I could get the concavity of the curve. An other way was just seeing for the value of the 5th derivative, as the concavity changes only in zero then I would know if it creases or decreases.
Bye, and thanks.
