Finding friction force with applied force at an angle
8 replies · 2K views · last reply
zstraught
A 2.4*10^2 N force is pulling an 85 kg refrigerator across a horizontal surface. the force acts at an angle of 20.0 above the surface. the coefficient of kinetic friction is .200, and the refrigerator moves a distance of 8.00 m. find (a) the work is done by the pulling force, and (b) the work is done by the kinetic frictional force
W=Fd
I drew a force diagram, Normal force up, weight down, force of friction to the left, and Force applied 20 degrees above the positive x axis.
I need clarification to find the force of Friction for part B. Should I set Force of friction equal to mu · normal force or should I use Newton's second law and set the force of friction equal to Fa·cos(20)? They both look like valid choices, but they both give different values of force of friction.
haruspex said:
What about acceleration?
Would it be 0 since it is moving at a constant velocity?
Where, in the problem statement, does it say that the velocity is constant? I couldn't find it.
I thought " A 2.4*10^2 N force..." means it is a constant velocity. If it isn't, how would I find the acceleration?
By finding the net horizontal force and dividing by the mass.
As you wrote:
zstraught said:
... Should I set Force of friction equal to mu · normal force or should I use Newton's second law and set the force of friction equal to Fa·cos(20)? They both look like valid choices, but they both give different values of force of friction.
The second choice is not valid.
You could pull that refrigerator with huge force and still couldn't increase the amount of kinetic friction resisting your effort.
That coefficient of kinetic friction being 0.20 means, in practical terms, that once you get that refrigerator moving and continue pulling it across that horizontal surface, the friction force that resists your pulling remains relatively constant at a value of 20% the weight of the refrigerator.
Please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/frict2.html#kin
Graph of frictional force against applied force: a straight red line rises from the origin for static friction, peaks at f_s = μ_sN, then drops to a flat level f_k = μ_kN. Dashed guides mark a point labelled f and F on the axes.
Lnewqban said:
##\dots## the friction force that resists your pulling remains relatively constant at a value of 20% the weight of the refrigerator.
Not quite. The pulling force has a vertical component, therefore the normal force is not equal to the weight.
Exactly!
Thank you, kuruman.
In this case, the pulling-up angle of 20° reduces the normal and friction forces some, as well as the the horizontal component of the pulling force, which is the one doing the positive work in question.
