Finding matrix inverse over Z5 from inverse over rationals
  • Thread starter Thread starter t_n_p
    Field Prime
3 replies · 3K views
t_n_p
Let A = [3 2 1; 0 1 4; 4 2 1]
(i) Find the cofactors C11, C12, C13, C21, C22, C23, C31, C32, C33 of A.
(ii) Given that det(A) = 7, use the adjoint method to find A-1.
(iii) Use the answer to part (ii) to find A-1 over the prime field Z5.
For (i) and (ii) I got inverse of A = 1/7[-7 0 7; 16 -1 -12; -4 2 3]
no problems here,
Just wondering how I do part (iii)
I've had a peek at the solutions and relevant textbooks, but can't seem to find anything.
Thanks
A "prime field" contains only positive integers. In particular, Z5 contains only {0, 1, 2, 3, 4}. That is, it does not explicitely contain "16/7" or -1/7. For that matter, it does not contain "-7/7= -1". But since 1+ 6= 7= 0 (mod 5), "-1" is really just "6". Knowing that 16/7= x (mod 5) is the same as 16= 7x what is x? (Remember that 16= 3(5)+ 1 so 16= 1 (mod 5) and 7= 1(5)+ 2 so 7= 2 (mod 5). 16= 7x (mod 5) is the same as 1= 2x (mod 5). The only possible values of x are 0, 1, 2, 3, 4 so just try each.
Reduce all of the values of A to (mod 5) form.
I understand the concept of mod 5, but I cannot comprehend all of it.
I can only make sense up to this part:
How does 7=0?
isn't 7mod5=0?
:confused:
Am I trying to satify the equation using only x values ranging from 1 to 4? Whole numbers only?
ok consider the first entry of column 1
1/7 (-7)
implies
-7 = 7a then mod 5 this
so
3 = 2a
note "a" can equal 0 1 2 3 4
so
3 = 2 * 0 = 0 mod 5 = 0 not true
3 = 2 * 1 = 2 mod 5 = 2 not true
3 = 2 * 2 = 4 mod 5 = 4 not true
3 = 2 * 3 = 6 mod 5 = 1 not true
3 = 2 * 4 = 8 mod 5 = 3 true
so first entry is 4
consider the second entry of column 1
16 / 7
implies
so
1 = 2a
note again "a" can equal 0 1 2 3 4
so
1 = 2 * 3 = 6 mod 5 = 1 true
the resultant matrix should be
[401,321,314]
