Finding Min. Element in Sequence: Algo & Steps
  • Context: MHB
  • Thread starter Thread starter evinda
    Element Sequence
The discussion focuses on developing an algorithm to find the minimum element in a sequence of numbers \( A = (a_1, a_2, \dots, a_n) \) with \( n \geq 3 \) using at most \( \lceil \frac{n}{2} \rceil \) comparisons. The proposed method involves comparing the first two elements and subsequently examining either the odd or even indexed elements based on which of the first two is smaller. The participants clarify the requirement of using \( \lceil \frac{n}{2} \rceil \) comparisons, ensuring the algorithm adheres to this constraint.
  • Understanding of algorithm design principles
  • Familiarity with sequence and array data structures
  • Basic knowledge of comparison operations in algorithms
  • Concept of time complexity and optimization techniques
  • Study the implementation of divide-and-conquer algorithms
  • Learn about optimization techniques for searching algorithms
  • Explore the concept of binary search and its applications
  • Investigate the use of data structures for efficient element retrieval
Algorithm developers, computer science students, and anyone interested in optimizing search algorithms within sequences.
evinda
MHB
Hello! (Smile)
We have a sequence of numbers $A=(a_1, a_2, \dots, a_n), n \geq 3$, for which, it stands the following:
$$\forall i \text{ with } 2 \leq i \leq n-1:$$
either
$$ 1. a_{i-1}<a_i \text{ and } a_i>a_{i+1}$$
or
$$2. a_{i-1}>a_i \text{ and } a_i<a_{i+1}$$
I have to write an algorithm, that finds the minimum element of $A$ with at most $\lceil \frac{n}{2} \rceil$ comparisons.
So, we have to compare the first two elements and if the first is smaller, we will just look at the elements of the odd positions, in order to find the minimum, and if the second element is smaller we will look at the elements of the even positions, right? (Thinking)
Then, how will we find the minimum of the remaining elements we are looking at? Using a while or is there an other way? (Thinking)
Technology news on Phys.org
evinda said:
I have to write an algorithm, that finds the minimum element of $A$ with at most $\lceil \frac{n}{2} \rceil$ elements.
Do you mean $\lceil \frac{n}{2} \rceil$ comparisons?
Yes, I am sorry... (Blush)
  • · Replies 58 ·
9K
  • · Replies 17 ·
