Finding Multiple Angles from Sine Values on the Unit Circle
9 replies · 2K views
Ethan
A straight wire 0.280 m in length carries a current of 3.40 A. What are the two angles between the direction of the current and the direction of a uniform 0.0400 T magnetic field for which the magnetic force on the wire has magnitude 0.0250 N?
F=ILBsin
I got 41 and correspondingly 49 from this. It said its wrong
Please show your work.
0.025=3.4*.28*.04sinx sin^-1(0.025/0.3808)=41
I have no idea where you got that, but am sure 0.025 does not equal 41.
I recommend that you show your work step by step and only put numbers in at the end.
It was two separate equations.
The 0.3808 appears to be a typo for a tenth of that.
41o appears to be correct. But why did you choose the complementary angle (49o) for the second angle?
sin(41o) ≠ sin(49o)
cos^-1(0.6565) is 86.2 but that didn't work. How am I supposed to find a second angle?
Draw two straight lines crossing. If one of the angles formed is x, what is the other?
Alternatively, if x=a is one solution of sin(x)=y, what is the other in the range 0 to 360?
You have shown that sinθ = .6565. So, you need to find two angles θ for which sinθ = .6565
You probably remember that sin(30o) = 0.5
Can you think of another angle whose sine is 0.5? What is the relation between the two angles?
Try this interactive unit circle. Click on the "Angles" button to display angles on the circle. As you move around on the circle, the length of the green line corresponds to the sine of the angle.
