Finding object density from tension in two strings with submersion
5 replies · 2K views · last reply
norcal36
You have two scales with a weight suspended from them on a string. Scale one has a tension of T1 and scale two has its mass submerged in water with tension T2. If you have T2<T1, find the density of the weight in terms of only density of the water, T1 and T2.
Density = mass/volume
Volume = mass/density
mass = density*volume
Buoyancy = Density of liquid*Volume Displaced*gravity
Hi new to the physics world and the symbiology is hard to understand completely. Attached is the work I've done to a final solution but I can't seem to get the answer in terms of only density of water and T1 and T2. Thank you for any assistance.
[ Mentor Note -- Word file replaced with a screenshot. Please use PDF or JPEG format for posting files. ]
Hello norcal, ##\qquad## :welcome: ##\qquad## !
If you can use MS equation, you can use ##LaTeX## too -- makes ist much easier to assist :rolleyes:
I love your word 'symbiology'
-- in this context I propose you create a variable ##V## for the volume of the weight. Definition of density ##\rho## (using a ##\delta## is confusing to others) is ##m = \rho V## . Rings a bell in the algebraic treatment ? [edit] greyed out after a cup of coffee and a decent read of your word doc :smile:
[edit] never mind, you are nearly there already: your last line reads $$\rho_b = {mg\; \rho_w\over T_1-T_2}$$ and to get it in the required form, you need something else for ##mg##. Guess ...
Thank you for that insight. With that I do get the correct answer with replacing the mg with T1. However, is there a way to manipulate the equation without just replacing that mg with T1? Again thank you for the insight!
Also I apologize for my inexperience with formatting . I don't know what LaTeX is and only way I could show my work was to use Word Possessor.
Click the link @BvU provided in post #2 for LaTeX.
Or use the pull-downs above the text entry panel:
##\sqrt x## for Greek letters, math symbols..
... for subscripts and superscripts.
