Finding Orthogonal Matrices: 2 Solutions and Help
This discussion focuses on finding orthogonal matrices, specifically two matrices derived from rotational properties and reflections. The first matrix identified is a rotation matrix with a determinant of -1, represented as \begin{pmatrix} -\cos( \frac {\pi} {4}) & \sin(\frac {\pi} {4})\\ \sin(\frac {\pi} {4}) & \cos(\frac {\pi} {4})\end{pmatrix}. The second matrix is obtained by changing the signs of the sine components. The discussion concludes that not all orthogonal matrices are rotations; some involve reflections, leading to a total of eight possible matrices when considering variations of \pm \frac{1}{\sqrt{2}}.
  • Understanding of orthogonal matrices and their properties
  • Familiarity with matrix multiplication and determinants
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Basic concepts of linear algebra, including vector dot products
  • Study the properties of orthogonal matrices in detail
  • Learn about matrix reflections and their implications in linear transformations
  • Explore the relationship between rotation matrices and their determinants
  • Investigate the general form of orthogonal matrices and their classifications
Mathematicians, students of linear algebra, and anyone interested in the properties of orthogonal matrices and their applications in various fields such as physics and engineering.
Poetria
Find four distinct orthogonal 2x2 matrices, each of which has top-left entry equal to ##-\frac {1} {\sqrt{2}}##
Definition of an orthogonal matrix:
##M^T=M^{-1}##
I have found two such matrices:
##\begin{pmatrix} -cos( \frac {\pi} {4}) & sin(\frac {\pi} {4})\\ sin(\frac {\pi} {4}) & cos(\frac {\pi} {4})\end{pmatrix}####\begin{pmatrix} -cos( \frac {\pi} {4}) & -sin(\frac {\pi} {4})\\ -sin(\frac {\pi} {4}) & cos(\frac {\pi} {4})\end{pmatrix}##
Any hint how to find the other two? I have tried several solutions but all of them were wrong.
How ?
Do the explicit matrix multiplication and solve the equations ...
  • Love
Oh, ok, I will try. Many thanks. :)
The first matrix is a rotational one: it's easy if you know its properties. The determinant is -1.
Then I have changed the signs of both sines and verified if the second matrix is orthogonal.
BvU said:
How ?
You sure ? I thought those have determinant 1 ...
Of course, I am wrong. I confused it with this one:
##\begin{pmatrix} cos(\pi/4) & -sin(\pi/4)\\ sin(\pi/4) & cos(\pi/4)\\\end{pmatrix}##
Anyway a rotational matrix was my point of departure. But I needed a negative cos(pi/4) in the top left corner.
I think you need to reflect a little more.
I think so. I will get to the bottom of it sooner or later. :)
Well, I have studied the definition of the orthogonal matrix:
https://mathworld.wolfram.com/OrthogonalMatrix.html
"The rows of an orthogonal matrix are an orthonormal basis. That is, each row has length one, and are mutually perpendicular."
There is a constraint: -1/sqrt(2) in the left top corner of the matrix.
So I have
## \sqrt {(-\frac {1} {\sqrt(2)})^{2}+x^{2}} =1##
##x= \frac {1} {\sqrt(2)}## v ##x= -\frac {1} {\sqrt(2)}##
There are two possibilities for the first row:
##\begin{pmatrix} -\frac {1} {\sqrt(2)} & \frac {1} {\sqrt(2)}\end{pmatrix}##
##\begin{pmatrix} -\frac {1} {\sqrt(2)} & -\frac {1} {\sqrt(2)}\end{pmatrix}##
The dot product of the first and second row has to be equal to zero.
vector (-1/sqrt(2), 1/sqrt(2)) dot vector (y, z) = 0
##\frac {z} {\sqrt(2)} - \frac {y} {\sqrt(2)}=0##
Therefore y=z.
But the length of the second row must be 1.
Therefore ##y=\frac {1} {\sqrt(2)}## v ##y=-\frac {1} {\sqrt(2)}##
The only thing I could do to obtain other matrices is change ##\theta##, e.g. instead of ##\sin(\frac{\pi} {4})## give ##\sin(\frac{9*\pi} {4})## but it's the same numerically.
Not all orthogonal matrices are rotations. In fact, only two are rotations. The others involve rotations and a reflection.
Or, you can simply work through the options for ##\pm \frac 1 {\sqrt 2}## in each entry. That gives 8 possibilities with minus in the first entry to check.
  • Love
Wow. :) I got it. :) Wonderful. Many thanks :)
A bit of quiet reflection was all it needed!
  • · Replies 21 ·
