Finding pendulum length from period and correct angular frequency equation
8 replies · 17K views
musicfairy
A simple pendulum has a period of 2 s for small amplitude oscillations.
1. The length of the pendulum is most nearly
(A) l/6 m
(B) ¼ m
(C) ½ m
(D) 1 m
(E) 2 m
I used the period of a pendulum equation, did some algebra, and got D as the answer. Is this correct?
2. Which of the following equations could represent the angle θ that the pendulum makes with the vertical as a function of time t?
(A) θ = θmax sin (π/2)t
(B) θ = θmax sin πt
(C) θ = θmax sin 2πt
(D) θ = θmax sin 4πt
(E) θ = θmax sin 8πt
I don't get this one. I'm assuming it's C because 2π = ω in a lot of equations and maybe it's true here too? Can someone please explain this?
1. Yes, good.
2. No. One way to think about this is, after one period the argument of the sine should be 2π. And you know what t is after one period.
I redid #2 this way.
T = 2π/ω
Substituted 2s for T and got ω = π
So the answer would be B?
Could someone help me out for #2. I'm not even sure how to approach that part.
They solved it check the previous posts ..
I saw the answer but I didn't understand why they are plugging in T. What exactly is the concept of θ = θmax sin Wt? I've never learned that so I don't know how to manipulate the equation.
you can reach to the equation θ = θmax sin Wt by considering (i.e.) a pendulum of length l and start from Newton`s 2nd law which states that net force = m x`` , with little work you will end up with the solution θ = θmax sin Wt, where W = sqrt(g/l) ..
you can approach the same answer by substituting l = 1m, g=10m/s^2 in W , then you will get W = 3.16 for g = 10m/s^2 (or W=3.13 for g=9.8 m/s^2) which is approximately equal to the answer they reached .. :)
