Finding preimage of vector with two parameters in linear system
7 replies · 2K views · last reply
Kernul
I have this linear application:
##f : \mathbb {R}^4 \rightarrow \mathbb {R}^4##
##f((x, y, z, t)) = (-2x - y + t, 2x + y - t, -4x - 2y + 2t, 0)##
and then I have this vector which I have to find the counter-image of it:
##\vec v = (-k, h - 2, k, h^2 - 4)##
With ##h## and ##k## real parameters that vary.
I already found out that the matrix associated with the linear application had rank ##1##.
So, now, I put the vector in the matrix as a column and we have:
##(A|\vec v) = \begin{pmatrix}
-2 & -1 & 0 & 1 & -k\\
2 & 1 & 0 & -1 & h - 2\\
-4 & -2 & 0 & 2 & k\\
0 & 0 & 0 & 0 & h^2 - 4
\end{pmatrix}##
I know that at this time I have to find the determinants and see what happens. The problem here is that I don't know how it works with two parameters, since I've always done it with just one. Do I have two different counter-image because of this? What does it change from the single parameter exercise?
From what I get, the determinants are ##2x2## so the rank is max ##2##, depending on the parameters. We would have:
##|A'| = h - 2 - k##
##|A''| = -2h + 4 - k##
##|A'''| = 2h^2 - 8##
If the last one is ##0## (so ##h = 2##), then the rank would be the same as the rank of the linear application's matrix, and so we could proceed. But what about the ##k## in the other two cases? Should I stick with ##h = 2## and then being forced to put ##k = 0##? Or I have to do it in a different way?
\end{pmatrix}##
Find the determinants? I don't know what you mean by this.
Just row-reduce the matrix above, and you should see what values of h and k must have.
I don't know what the equations above represent. What are A', A'', and A'''?
In my work, I found that it must be true that k = 0 and h = 2. The preimage of f (what you're calling the counterimage) is a three-dimensional subspace of R4.
Our professor taught us to find the determinants and then the rank. If the parameter is equivalent to a number that would make the rank of the ##(A|\vec v)## equal to the rank of ##A##, then we have to find the preimage by putting the number that the parameter is associated with.
For example, if ##h = 2## this implies that ##rank(A) = rank (A|\vec v)## and so we put all in a system and start the calculus to find the preimage.
These are the three determinants that are different from ##0##.
##A' = \begin{vmatrix}
1 & -k\\
-1 & h - 2
\end{vmatrix}##
##A'' = \begin{vmatrix}
-1 & h - 2\\
2 & k
\end{vmatrix}##
##A''' = \begin{vmatrix}
2 & k\\
0 & h^2 - 4
\end{vmatrix}##
Should I row-reduce the matrix always in this kind of exercise?
I would have something like this if I row-reduce:
\begin{pmatrix}
-2 & -1 & 0 & 1 & -k \\
0 & 0 & 0 & 0 & h - 2 - k\\
0 & 0 & 0 & 0 & 3k\\
0 & 0 & 0 & 0 & h^2 - 4\\
\end{pmatrix}
And in a system would be:
\begin{cases}
-2x - y + t = -k \\
0 = h - 2 - k \\
0 = 3k \\
0 = h^2 - 4
\end{cases}
\begin{cases}
-2x - y + t = 0 \\
h = 2 \\
k = 0 \\
h = 2
\end{cases}
Is this right?
Forget determinants. In fact, why even bother with matrices? You have a simple linear system of 4 equations in 4 unknowns:
$$\begin{array}{rcl}
-2x-y+t&=&-k \\
2x+y-t&=&h-2\\
-4x-2y+2t&=& k\\
0 &=&h^2-4
\end{array}
If ##h = 2## or ##h = -2## you will be left with three equations in the three unknowns ##x,y,t##, which you can just solve using elementary elimination methods faster than you could even write down the matrices. If ##h \neq \pm 2## your ##\vec{v}## cannot "come from" any ##(x,y,z,t)## via ##f(x,y,z,t)##. The variable ##z## does not appear anywhere in your ##f(x,y,z,t)## as you have written it.
I don't understand how to resolve that system. I ended up with something like this:
##\begin{cases}
-h + 2 = -k \\
y = -2x + t + h - 2 \\
-2h + 4 = k \\
h = \pm 2
\end{cases}##
Did I do something wrong?
Ray Vickson said:
If h≠±2h≠±2h \neq \pm 2 your ⃗vv→\vec{v} cannot "come from" any (x,y,z,t)(x,y,z,t)(x,y,z,t) via f(x,y,z,t)f(x,y,z,t)f(x,y,z,t)
I don't understand what you mean by "##\vec v## cannot come from any ##(x, y, z, t)## via ##f(x, y, z, t)##". You mean that it doesn't have a preimage if it's not ##h \neq \pm 2##?
##\begin{cases}
-h + 2 = -k \\
-2h + 4 = k \\
h = \pm 2
\end{cases}##
Did I do something wrong?I don't understand what you mean by "##\vec v## cannot come from any ##(x, y, z, t)## via ##f(x, y, z, t)##". You mean that it doesn't have a preimage if it's not ##h \neq \pm 2##?
Yes, that is exactly what I mean: the resulting ##\vec{v}## is not in the "range" of ##f(x,y,z,t)##.
Anyway, if ##h = 2## the equations imply that ##k = 0##, and so the resulting pre-image of ##\vec{v}## is ##\{(x,y,z,t): t = 2x+y, x,y,z,\in R \}##. Now look at the other case, ##h = -2##, to see what you get.
Ray Vickson said:
Now look at the other case, h=−2h=−2h = -2, to see what you get.
I would have ##k = 8## and ##k = -4##, which is impossible so it HAS to be ##h = 2##, right?
Yes, I believe so.
