Finding Pressure Decay in Pneumatic System with RK4 Method
  • Thread starter Thread starter shekhar
2 replies · 689 views
shekhar
I want to find the pressure decay of two volumes V1 and V2 having orifices d1 and d2 at their outlets respectively. The differential equations for the pressure and temperature for the two volumes are given below.
i solved these equations using RK4 method. The solutions I got are quite realistic. But the solutions fails when : both the volumes are at same pressure (P2=P1) outlet of V2 is closed at t=0. It is suddenly opened at t=0. when we solve the above DE for P2, k1 in this case is negative (since first term becomes 0) whereas k2 becomes positive. This causes k3 to be imaginary! Can anyone help me with this? Thanks in advance!
Hi shekhar, welcome to PF!
This forum (New Member Zone) is just for introductions. You should ask "real questions" (physics, engineering, math, etc.) in an appropriate forum. For this question, I'd suggest the Mechanical Engineering forum, in the Engineering section.
Thank you jtbell. This info helped me a lot.
