Finding quotient using while loop
7 replies · 4K views · last reply
DryRun
Suppose that the number ##\pi## is divided by 2. The resulting quotient is divided by 2 again. This process is continued till the current quotient is less than or equal to 0.01. What is the largest quotient that is greater than 0.01?
Here is my attempt:
Code:
r = 1;
quo = 1;
while  (quo  >  0.01)
quo  =  pi / 2;
num(r) = quo;
r = r+1;
end
disp('The largest quotient greater than 0.01 is: ' ,(num(r-1)) )
The processing takes about 20 or 30 seconds and then i get this error in the command window:
Out of memory. Type HELP MEMORY for your options.
Error in piquo (line 7)
num(r) = quo;
Here is my attempt:
Code:
r = 1;
quo = 1;
while  (quo  >  0.01)
quo  =  pi / 2;
num(r) = quo;
r = r+1;
end
num(r) = quo;
It might be better to take the quo=pi/2 statement outside of the while loop ...
Here is the modified script:
Code:
r = 1;
quo = 1;
while  (quo  >  0.01)
num(r) = quo;
r = r+1;
end
quo  =  pi / 2;
But Matlab just keeps processing, and then crashes.
Maybe you meant to use a nested while loop? I don't know how that would work.
I'm quite sure that i need to use a while loop in this problem, as i don't know how many iterations are required for the quotient to become less than 0.01. num(r) is an array that represents the index which contains the corresponding quotient, based on the number of times r that the while loop is executed.
Code:
r = 1;
quo = 1;
while  (quo  >  0.01)
num(r) = quo;
r = r+1;
end
quo  =  pi / 2;
No, what I meant was your loop kept setting quo to pi/2 as its first action, hence why it didn't terminate. You have a similar problem with your revised loop in that you never change quo.
Have a look at the attached Mathcad example of what I think you want to achieve.
  • Mathcad worksheet: quo set to pi, then a while loop while quo > 0.01 that appends quo to a vector r and sets quo to quo/2; the resulting column r lists 3.142, 1.571, 0.785, 0.393, 0.196, 0.098, 0.049, 0.025, 0.012.
Here is the revised code:
Code:
r = 1;
quo = pi;
while  (quo  >  0.01)
quo  =  quo / 2;
num(r) = quo;
r = r+1;
end
disp(num(r-2))
I believe it's correct, as i get the answer: 0.0123
However, i cannot display the line: The largest quotient greater than 0.01 is: 0.0123
I tried this format but it didn't work: disp('The largest quotient greater than 0.01 is: ' ,num(r-2) )
Code:
r = 1;
quo = pi;
while  (quo  >  0.01)
quo  =  quo / 2;
num(r) = quo;
r = r+1;
end
disp(num(r-2))
I'm not a Matlab user, so don't take what I say as Gospel, but I don't think disp works like that. According to the on-line Help, you've got convert the number to a string and, for example, concatenate it with your string. See http://www.mathworks.co.uk/help/techdoc/ref/disp.html for details.
PS. The code looks better now and the result seems OK.
sharks said:
OK, thanks for your help, NemoReally.
No worries.
