Finding solutions for x<0 in a differential equation
  • Thread starter Konig
Konig
Hi,
I have solved a differential equation (1) for x, where i think is a real variable.
(1) [tex]\frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1+x)^2}[/tex]
And get a solution
[tex]y(x) = \frac{2}{\sqrt{x}} - \frac{\sqrt{x}}{(1+x)} - 3 \arctan{\sqrt{x}}[/tex]
Now, i want to find solutions for x<0, and i have said that the above is a solution for x>0.
So far i have simply done a coord transformation x→-x and then solved this equation
[tex]\frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1-x)^2}[/tex]
and then substituted in "-x" under my square roots.
Is this a correct way of finding x<0?
Konig.
Konig said:
Hi,
And get a solution
[tex]y(x) = \frac{1}{\sqrt{x}} - \frac{\sqrt{x}}{(1+x)} - 3 \arctan{\sqrt{x}}[/tex]
Konig.
What do you plan to do about the square root of negative numbers?
Konig.
So [tex]\sqrt{-x}, x<0[/tex] will give a positive answer.
Although I am not sure what to do about the [tex]x^{\frac{3}{2}}[/tex] part of the equation.
The answer should have natural logs and some x terms.
the solution of [tex]\frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1-x)^2}[/tex]
gives a similar answer to what i need which gives me hope. But I am not sure what the do with the first terms, eg there signs etc.
thanks.
You can't arbitrarily change the sign of x under the radical.
This will show the problem:
[itex]\displaystyle\sqrt{x}=\sqrt{(-1)(-1)x}[/itex]
[itex]\displaystyle =\left(\sqrt{-1}\,\right)\sqrt{-x}[/itex]​
What will you do with [itex]\sqrt{-1}\,?[/itex] -- even if you call it i .
