Finding tan(½ arcsin(-7/25)) using half-angle formula
  • Thread starter jrjack
11 replies · 8K views · last reply
jrjack
[tex]\tan[\frac{1}{2} \arcsin(\frac{-7}{25})][/tex]
I'm not sure how to take 1/2 the arcsin, should this use the half-angle formula?
Normally I would draw a triangle using the sin value (-7/25), then find the tan value (24/25), but the 1/2 is throwing me off.
How do I start this? Is this 1/2 the sin value (-7/25)= -7/50, then solve for the tan(-7/50)?
Use the tangent half angle formula. tan(x/2)=??
Thanks, so i get
[tex]-\sqrt{26}[/tex]
Does that sound right?
jrjack said:
Thanks, so i get
arcsin(-7/25) is about -0.3. If you take half of that and take the tangent, it's nowhere near -sqrt(26) which is about -5. Is it? You can check these solutions using rough estimates or a calculator.
[tex]-\sqrt{\frac{1+\cos x}{1-\cos x}}[/tex]
[tex]-\sqrt{\frac{1+\frac{24}{25}}{1-\frac{24}{25}}}[/tex]
[tex]=-\sqrt{26}[/tex]
tan(0/2)=0. If you put x=0 into your supposed half angle formula, what do you get? Does it work?
Sorry, I now realize I have my signs flipped in my formula.
I think my answer should be:[tex]-\sqrt{\frac{1}{26}}[/tex]
That doesn't work either because (1-24/25)/(1+24/25) isn't equal to 1/26. Now what's it really equal to??
Sorry, I got in a hurry, between typing the tex and working the problem several different ways (wrong of course).
It should equal 1/49, which means my answer should be [itex]-\sqrt{\frac{1}{49}}[/itex]
Ok, aside from the fact there is a simpler way to write -1/sqrt(49) could you try and check that using a calculator from your original expression? It's really useful to have a simple way of self-checking whether you are way off or not.
Thank you for your help.
I realize I still need to rationalize the denominator, and after checking with my calculator both answers come out to -.142857, so that must be correct.
My final answer should be -1/7
Once again, thank you for your help.
Very welcome and quite right. The main lesson is how easy these answers are to check with a calculator.
