Finding Tension in String Connected to Electrically Repelled Sphere
The problem involves two uniformly charged spheres suspended by strings, in static equilibrium, with given angles and one known tension value. The objective is to find the tension in the second string while considering the forces acting on both spheres.
  • Participants discuss the static equilibrium of the spheres and the relationship between the tension components. There is an exploration of whether the spheres can be assumed to be at the same height to simplify the calculations. Questions arise regarding the missing mass values and how they affect the y component of the tension.
The discussion is ongoing, with participants providing insights into the relationships between the forces and tension components. Some guidance has been offered regarding the equivalence of horizontal components, but there is still uncertainty about how to proceed without the masses of the spheres.
The problem lacks specific mass values for the spheres, which complicates the calculation of the y component of the tension. The setup involves adjustable supports, raising questions about the height of the spheres.
velouria131
Two uniformly charged spheres are suspended by strings of length L from vertically adjustable supports. The spheres are in static equilibrium.
The angles with respect to the vertical are Q=14.9°, and T=20.7°.
The tension in the string supporting sphere Z (Z with respect to angle T, W is the other sphere and hangs with respect to angle Q) is 2.41E-5 N. Calculate the tension in the other string.
Fe = k (q1 * q2 / (r) ^ 2)
Fg = mg
Alright, here is a brief overview of what I have done. I first recognized that the system was in static equilibrium. Thus, for each sphere I wrote equations representing the force components, and set each equation to zero. Each sphere operates under the same conditions.
Sphere Z lies to the left (T is force due to tension, Fe is force due to Electric repulsion)
Tx = Tcos∅
Ty = Tsin∅
T = 2.41E-5 N
0 = Tx - Fe
0 = Ty - mg
Sphere W lies to the right:
Tx = Tcostheta
Ty = Tsintheta
0 = -Tx + Fe
0 = Ty - mg
So, I recognize that in each case, the x-component of the tension in each string is equivalent. This makes sense because the forces on each sphere with respect to the x-axis are due to the electric force. This force has an equal and opposite effect. I cannot figure out how to find the total tension in the second string, even though I know the x component etc. Any help in progressing from this point would be greatly appreciated.
The question states that the spheres are on vertically adjustable supports. Are we allowed to assume that the spheres are at the same height, because this would simplify the question to equating horizontal tension components.
Yes, absolutely. There is a diagram I can include if that is needed. The horizontal components are equivalent. However, the masses are not given, so I haven't a clue how to find the y component of the tension in the second string.
But you have its x component Tx and an angle ∅ and Tx=Tcos∅
  • · Replies 18 ·
  • · Replies 19 ·
