Finding tensions and angle in a three-string static equilibrium system
7 replies · 9K views · last reply
janelle1905
The system (picture found in attachment) is in static equilibrium, and the string in the middle is exactly horizontal.
Find
a. Tension T1
b. Tension T2
c. Tension T3
d. angle (theta)
sin=opp/hyp
cos=adj/hyp
a. Using Ty = T1sin60 - mg = 0, T1=34 N.
b. Using Tx = T2 - T1cos60 = 0, T2 = 17 N
c. Eq'n 1: Tx = T3sin(theta) - mg = 0
Re-arranged to: theta = cos-1 T2/T3
Eq'n 2: Ty = T3sin(theta) - mg = 0
Then I substituted the re-arranged eq'n (1) into eq'n (2), and I got this:
0 = T3sin(cos-1 T2/T3) - mg
However, I don't know how to solve this ... so I think I may be doing something wrong.
Thank you in advance for any assistance!
Sorry, there is no attachment that I can see and without it I don't want to guess at what the picture looks like.
Very sorry about that!
I have added the attachment to this post...hopefully it works this time!
  • Hand-drawn free-body diagram of two masses hanging from a horizontal string: T1 and T2 at the left and right knots, angle 60° marked at the left and θ at the right, M1 and M2 labelled below, and T3 pulling up and to the right from the right knot.
Parts (a) and (b) look OK.
Part (c)
If you draw the FBD for the mass m2, you get
T3sinθ - m2g = 0
- T2+T3cosθ = 0
So T3sinθ = m2g
and
T3cosθ = T2
These are the horizontal and vertical components of the tension. Can you find its magnitude?
Thanks so much for your help :)
Using the following equations:
1. T3sinθ - m2g = 0
2. - T2+T3cosθ = 0
I re-arranged and substituted eq'n 1 into 2, and then calculated theta=49o.
The only thing I wasn't sure about was when I had cos(theta)/sin(theta), I simplified it to 1/tan(theta). Is this the correct was to use the trig identity tan=sin/cos ??
Then I substituted the calculation for theta to calculate T3=26 N.
Your method is fine. What I was hinting at is that if you know the x and y components of T3, then the magnitude is given by
T3=[T3x2+T3y2]1/2 = [(m2g)2+(T2)2]1/2
and, as you pointed out, you get the angle from
tanθ = T3y / T3x = m2g / T2
Okay I see what you were saying - but you get the same answer either way, correct?
