Finding the aproximate integer Sqrt of a large prime
  • Level: Graduate
  • Thread starter Thread starter Facet
    Integer Prime
Facet
I am trying to understand how I can find the square root of a large prime number in the form of an integer value, the portion after the decimal is irelevant.
The numbers I wish to compute range around 188 multiplied by 3 to the power of 6548 plus 1, as an example. so let's say in excess of 3000 digits.
My problem with this is, using my quad-core machine, I'm finding my petty division through subtraction routine fairly slow, and (x+a/x)/2 as a solution is failing badly.
Can someone please find time to discuss with me a way of doing this?
Can a prime have a GCD with a smaller number(like the sqrt), I somehow just don't see it...
So if there is an easy solution, please let me know it =)
Mathematics news on Phys.org
You don't need to do any division at all.
Just use (x+k)^2 = x^2 + 2kx + k^2
Call your prime p. Start with x = the largest value of [itex]2^m[/itex] where [itex]x^2 < p[/itex], and [itex]k = x/2[/itex]
Find (x+k)^2. If it is less than p, let x = x+k.
Divide k by 2 and repeat, until k = 1.
If your big arithmetic routines work in decimal not binary, you can use the same sort of algorithm to pick off one decimal digit of the answer at a time.
You don't need to spend time calculatiing the right-hand digits of the numbers that you know are zero, of course.
Thankyou for the quick reply, much appreciated... =)
I really need to touch up on my maths =(
I'm sure what you posted will help me out...
I can straight away see how much faster that would be ;)
one quick question - what is m
Edit: nvm - I think I see what you say =)
