Finding the Convolution of Two Functions Using the Laplace Transform
6 replies · 2K views · last reply
redundant6939
[itex]x(t) = cos(3πt)[/itex]
[itex]h(t) = e<sup>-2t</sup>u(t)[/itex]
Find [itex]y(t) = x(t) * h(t)[/itex](ie convolution)
Y(s) = X(s)H(s) and then take inverse laplace tranform of Y(s)
[itex]L(x(t)) = [πδ(ω - 3π) + πδ(ω + 3π)][/itex]
[itex]L(h(t)) = \frac{1}{s+2}[/itex]
Laplace Transform inverse :
[itex]y(t) = \frac{1}{2} \int \frac{e^{st}}{s+2} * δ(w-3π)[/itex] + [itex]\frac{1}{2} \int \frac{e^{st}}{s+2} * δ(w+3π)dt = \frac{1}{2} \frac {e^{3sπ} + e^{-3sπ}}{s+2}[/itex]
Im not sure about direc delta integration..
The Laplace transform of ##\cos 2\pi t## isn't what you said it is. (It should be a function of ##s##, not ##\omega##.) You're thinking of the Fourier transform.
Is it [itex]\frac {s}{s^2 + (3π)^2}[/itex] ?
Yes. Usually, it's assumed you're working with the unilateral Laplace transform, and you essentially ignore what's going on before t=0. Are you supposed to be using the bilateral Laplace transform?
redundant6939 said:
But isn't that the LT of cos(3pi*t)u(t)?
The "bilateral" transform of ##\cos(3 \pi t)## does not exist, because the integral
[tex]\int_{-\infty}^{\infty} e^{-st} \cos(3 \pi t) \, dt[/tex]
is not convergent. However, the "unilateral" LT of ##u(t) \cos(3 \pi t)## certainly does exist.
