Finding the cutoff Xmin where we reject the null hypothesis
  • Thread starter t.kirschner99
10 replies · 2K views · last reply
t.kirschner99
A random sample of X1, X2, · · · , Xn is taken from a population of values that is modeled by the following probability density function:
f(xi; β) = e-(xi-β), xi≥β
Suppose we test the hypothesis:
Ho: β = 1 , HA: β > 1
a) Suppose you are to test the above hypothesis based on a random sample of n = 10 data points and regulating the probability of committing Type I Error to be 0.05. State the values of Xmin in that would indicate that β > 1.
f(Xmin;β) = ne-n(Xmin - β), Xmin ≥ β
Handwritten derivation on lined paper finding a cutoff value c for Xmin in a Type I error test, with integrals of n e^(-n(Xmin - β)) and the equation 0.05/e^(nβ) = -e^(-nc) + e^(-n) for n = 10, β = 1.
Getting stuck at the end due to the negative natural log situation that develops... was wondering if anyone would be able to point out the mistake I have made. The scribble at the end there ended up giving me a negative "c" value, which does not make sense as it is less than β.
Thanks!
  • Handwritten derivation on lined paper finding a cutoff value c for Xmin in a Type I error test, with integrals of n e^(-n(Xmin - β)) and the equation 0.05/e^(nβ) = -e^(-nc) + e^(-n) for n = 10, β = 1.
Thanks!
It would be nice to have the full problem statement. What is the hypothesis you are testing?
As to your negative c value, -ln(x) is not necessarily negative. It depends on the value of x.
Oh, OK, I see that ##c= 1 + \frac {ln(.05)} {10} - 1## would be negative.
I have added the whole problem to the original post. The Xmin formula was given to us in the question.
I can't read your solution photo, so let's start at the beginning. What plan are you following in solving this problem?
Sorry about the quality of the photo. I'll include a new photo at the bottom of this post.
For my strategy in this problem, the question asked for me to find the cutoff value using the Type I error of 0.05. Thus, I started with the Type I error definition which is...
α = P(Reject Ho | Ho is true)
The first part of the above probability statement is using the Xmin, while the last part is using the hypothesis given to us, therefore the completed probability statement is:
0.05 = P(Xmin < c | β = 1)
And from there, I did the work outlined in the photo below:
Handwritten derivation on lined paper finding cutoff c from 0.05 = integral of n e^(-n(xmin - beta)) dxmin, with n = 10 and beta = 1, ending with c = blank.
If the photo is still unreadable, i'll go ahead and type it up.
EDIT: I'll say that the embedded photo is a lot more blurry than the one on the imgur link. Here is the direct link to it: https://imgur.com/a/Dj4yN
  • Handwritten derivation on lined paper finding cutoff c from 0.05 = integral of n e^(-n(xmin - beta)) dxmin, with n = 10 and beta = 1, ending with c = blank.
In the lines you crossed out, you took ##ln(e^{-10c} + \frac {0.05} {e^{10}})## and got ##-10c+ln(\frac {0.05} {e^{10}})##. Do you see why that is not correct?
Here something that would simplify your derivation: What is ##\frac d{dx} e^{-n(x-β)}##?
Another useful fact in problems like this is,
for ##x_i## iid and ##x_{min} \equiv \begin{matrix} minimum\\i \end{matrix}x_i##,
##P(x_{min}>c)=\prod_{i=1}^n P(x_i>c)=P^n(x>c)##.
This makes it easy to get the cdf of ##x_{min}##.
a) Yes, ln(x+y) does not equal ln(x) + ln(y), only ln(xy) = ln(x) + ln(y). Think that scribble on the bottom was my brain losing grasp of reality lol.
b) ##\frac d{dx} e^{-n(x-β)}## = ##-n e^{-n(x-β)}##. Therefore, the anti-derivative is ##\frac {-1}{n} e^{-n(x-β)}##.
c) Before getting to the last part of your response, I realized that I may have over simplified (leading to a wrong simplification) in my original response. I went ahead and redid it without separating the β term from the integrand and got an answer of 1.005129 for c. Unfortunately, I don't have the answer, but it is a value that is greater than 1.
Now my question for the ##P(x_{min}>c)=\prod_{i=1}^n P(x_i>c)=P^n(x>c)## term you stated. Is it necessary to use that in the question or is the answer attainable by evaluating the anti-derivative above between the bounds [1,c]? I would assume if you use the equation you stated above, you would have to assume that α = P(Xmin > c | β=1)?
Thanks for your help with this!
That is the correct answer.
No, this is not required to work the problem since you already have ##f(x_i; β) = e^{-(xi-β)}##. It would give you an alternate way to work the problem. If you start with ##α = P(X_{min} \leq c | β=1)##, then ##1-α = P(X_{min} > c | β=1)##.
tnich said:
That is the correct answer.No, this is not required to work the problem since you already have ##f(x_i; β) = e^{-(xi-β)}##. It would give you an alternate way to work the problem. If you start with ##α = P(X_{min} \leq c | β=1)##, then ##1-α = P(X_{min} > c | β=1)##.
Thanks for the help on this question!
Actually, this is not quite the correct answer, the question asks for "the values of Xmin in that would indicate that β > 1". So you will need to state an interval of values for c.
