Finding the joint moment generating function given the joint PDF
8 replies · 5K views · last reply
stripes
Typeset problem statement: joint density f(x, y) equals 1 over root 2 pi times e^(-y) e^(-(x-y)^2/2) for minus infinity < x < infinity and 0 < y < infinity, and 0 otherwise. Parts (a) and (b) ask for moment generating functions.
Equation for the joint moment generating function M(X,Y)(t,s) = E[e^(tX+sY)], written as a double integral from 0 to infinity in x and from minus infinity to infinity in y of e^(tx+sy) f(x,y) dx dy.
The problem is the integral is non-elementary, so now what? Part (b) follows trivially from part (a). But is there some kind of shortcut I have to take, because no matter what substitution I do, the integral needs to be written in terms of the error function, which is out of the scope of this course. Any hints would be great. Thanks.
  • Piecewise joint density f(x,y) equals 1 over sqrt(2 pi) times e^(-y) e^(-(x-y)^2/2) for minus infinity less than x less than infinity and 0 less than y less than infinity, and 0 otherwise; followed by parts (a) and (b) on moment generating functions.
  • Equation for a joint moment generating function: M_{X,Y}(t,s) = E[e^{tX+sY}] = integral from 0 to infinity and integral from minus infinity to infinity of e^{tx+sy} f(x,y) dx dy.
Try something.
Try integrating over x for example.
You will be surprised.
it seems something will just "vanish" but i can't find what, mainly because there is always the factor of e^x in there that gets in the way. I realize that it looks like a bivariate normal distribution though...
Try integrating on x, as a start.
Since the integration spans [-Inf, +Inf], you will end up with a definite integral.
Alternatively, you might re-use known results on Laplace transforms.
See for example:
http://planetmath.org/laplacetransformofagaussianfunction
Proving what you find there is not difficult and could be interesting.
Other hint: 2bx + x² = (x+b)² - b²
stripes said:
Piecewise joint density f(x,y) equals 1 over sqrt(2 pi) times e^(-y) e^(-(x-y)^2/2) for -infinity < x < infinity and 0 < y < infinity, and 0 otherwise; followed by parts (a) and (b) asking for moment generating functions.
Typeset equations defining the joint moment generating function M_{X,Y}(t,s) as E[e^{tX+sY}], equal to the double integral from 0 to infinity (outer) and minus infinity to infinity (inner) of e^{tx+sy} f(x,y) dx dy.
Do the x-integration first; it has the form
[tex]G(t,y) = \int_{-\infty}^{\infty} e^{-y} e^{tx} e^{-(x-y)^2/2}/\sqrt{2 \pi} \, dx[/tex]
Basically, this is a standard Gaussian integral, and it can be done in closed form because the integration limits are ##\pm \infty##. See. eg., http://en.wikipedia.org/wiki/Gaussian_integral .
to me, e^-(x-y)^2 looks like a gaussian integral. but with the extra e^(tx), it no longer looks like a "standard" gaussian integral. of course i can see that because the limits are +/- infinity, that the x integration is just going to give root pi, or 1 or something stupid easy, but I'm not terribly familiar with WHAT the actual volume is under the 3d graph of a standard gaussian, let alone a gaussian with an extra e^(tx) in it...
wolfram gives
http://www4b.wolframalpha.com/Calculate/MSP/MSP11611geaf4ba3b24ad0800005cf7hi62g6gf6c5i?MSPStoreType=image/gif&s=23&w=230.&h=49.
as the integral wrt x. i can't "see" that. but it looks like it follows from maajdl's suggestion...
First perform the first integral.
If you want to walk, you need a first step.
And you will see that the second will be much easier than the first step.
That's really a general rule: don't delay the first for the reason that you do not trust the second step.
You didn't write here the step where you experience a difficulty.
I can a most guess what is your problem (if any).
Therefore, I add this hint:
Exp(-2bx - (x+c)²) = Exp(-(x+b+c)² + b²) = Exp(-z²+b²) = Exp(b²) Exp(-z²)
where z = x+b+c
