Finding the Length of the Right Angle Bisector
  • Context: MHB
  • Thread starter Thread starter Heatherirving
    Angle Length
The discussion revolves around calculating the length of the angle bisector in a right-angled triangle with given leg lengths. Participants explore different mathematical approaches, including the Pythagorean theorem, Law of Cosines, and coordinate geometry.
  • One participant presents a calculation problem involving the right-angled triangle and seeks assistance in determining the length of the angle bisector.
  • Another participant suggests using the Pythagorean theorem and the Law of Cosines to derive relationships between the triangle's sides and the angle bisector.
  • Further equations are proposed involving trigonometric functions and relationships between the segments of the triangle.
  • A different approach using coordinate geometry is introduced, positioning the triangle in the first quadrant and deriving the length of the angle bisector through substitution into the equations of the triangle's sides.
  • One participant expresses appreciation for the assistance provided in the discussion.
Participants present multiple approaches to the problem, including the Law of Cosines and coordinate geometry, indicating that there is no consensus on a single method or solution. The discussion remains open with various viewpoints and calculations being explored.
Some assumptions regarding the properties of the triangles and the applicability of different mathematical laws are not explicitly stated, which may affect the validity of the approaches discussed.
Heatherirving
Hello
I would need help to continue.
calculation problem:
Given a right angled triangle with catheter lengths a and b length units, determine and indicate the length of the bisectris to the right angle.View attachment 6595
find: Xa^2 + b^2 = (y+z)^2X^2 + y^2 = a ^2X^2 + z^2 = b ^2
Mathematics news on Phys.org
I agree that we can apply the Pythagorean theorem to the right triangle:
$$a^2+b^2=(y+z)^2$$
However, for the two smaller triangles, they aren't necessarily right triangles, so we could apply the Law of Cosines instead:
$$z^2=x^2+b^2-\sqrt{2}bx$$
$$y^2=x^2+a^2-\sqrt{2}ax$$
Adding these last two equations together, we find:
$$y^2+z^2=2x^2+a^2+b^2-\sqrt{2}(a+b)x$$
Application of the Law of Sines yields (where $\theta$ is the angle subtended by $b$ and $z$):
$$\frac{x}{\sin(\theta)}=\sqrt{2}z$$
$$\frac{x}{\cos(\theta)}=\sqrt{2}y$$
Multiplying them together and rewriting the trig. functions as ratios, there results:
$$2yz=\frac{x^2(a^2+b^2)}{ab}$$
Adding this to the previous sum, we get:
$$y^2+2yz+z^2=2x^2+\frac{x^2(a^2+b^2)}{ab}+a^2+b^2-\sqrt{2}(a+b)x$$
Can you proceed?
Many thanks for your help; :)
Another approach would be to use coordinate geometry...we orient the right triangle in the first quadrant with the right angle at the origin, and to the hypotenuse lies along the line:
$$\frac{x}{a}+\frac{y}{b}=1$$
And the line segment labeled "x" lies along the line:
$$y=x$$
Substituting for $y$ into the first equation, we find:
$$\frac{x}{a}+\frac{x}{b}=1$$
Hence:
$$y=x=\frac{ab}{a+b}$$
Since the diagonal of a square with sides $s$ is $\sqrt{2}s$, we conclude the length of the segment labeled "x" is:
$$x=\frac{\sqrt{2}ab}{a+b}$$
And this agrees with the eventual outcome of my first post in this thread. :D
wonderful :o
