Finding the maximum compression of a spring
The problem involves a collision between two masses, m1 and M2, where a spring is compressed upon impact. The context is centered around concepts of momentum, energy, and the behavior of the system during the collision.
  • Participants discuss the relevance of momentum and energy conservation laws, questioning how these principles apply to the collision. There are attempts to describe the motion of the masses and the spring's behavior during compression.
The discussion is ongoing, with participants exploring various physical laws and concepts that may apply to the problem. Some guidance has been offered regarding the center of mass and energy considerations, but no consensus has been reached on a specific approach.
Participants note the absence of horizontal forces and the implications for kinetic energy and momentum. There is also a mention of the professor's expectations regarding the use of center of mass and momentum thinking in the solution.
kappakeepo
A block of mass m1 slides along a frictionless table to the right with a speed of v1. A second mass M2 slides in the same direction with a speed of v2 such that it will collide with m1 which is in front of m2. Say that a spring of stiffness k is attached to one of the masses such that it compresses when the two masses finally collide. Find the maximum compression of the spring.
It sounds like momentum to me so I guess F=dp/dt will be relevant here.
Now I think max compression occurs when velocity of mass 1 relative to mass 2 is zero. But that's the only thing I could really figure out. I don't know what to proceed next. Can anyone help me?
What sort of physical laws will be relevant here? "something to do with momentum"? ... what laws do you know about momentum? Are there any other laws you know about that could apply?
Can you describe, qualitatively, what happens during the collision?
I'm thinking centre of mass might be relevant here but I don't know how. It's a gut feeling. Also definitely F=-kx during collision.
During the collision, momentum from the left mass is transferred to the right mass. I believe this is an elastic collision.
Is there anything else you know about the blocks while they're in motion? Any other properties they have that you could use?
Well. There's no horizontal force obviously since a = 0. Since it is in motion, there has to be kinetic energy and momentum (relative to that frame of reference to be exact)
Do you know any laws about the energy?
Center of mass may be a promising approach, especially if you have just done a lot of coursework on center f mass problems - can you describe the motion in the com frame?
@Jason Healy: welcome to PF
Yes but I think my professor wants me to do this question using centre of mass thinking or momentum thinking or both. But I'm not sure using laws of energy is a must here.
Laws of energy are always available - right now you are collecting your ideas.
Center of mass may be a promising approach, especially if you have just done a lot of coursework on center of mass problems - can you describe the motion in the com frame?
Well. Since both bodies have no acceleration(no horizontal force), then the centre of mass of both bodies must have a=0. Also V of com is moving right. The collision occurs at the final centre of mass obviously.
While the spring is being compressed - don't the bodies accelerate?
Can you think of a general principle for energy and momentum that may hold for the interaction here?
Describe the motion in the center of mass frame.
