Finding the Normal and Intersection Points on a Parametric Circle Curve
8 replies · 4K views · last reply
thereddevils
Find the equation of normal to curve x=cos b , y=sin b at the point where b=pi/4 . Find the coordinates of the point on the curve where the normal meets the curve again .
Gradient of normal :
dx/db=-sin b
dy/db=cos b
dy/dx=-cot b
gradient of normal = tan b , when b=pi/4 , gradient of normal =1
The normal cuts the curve at point (1/sqrt(2) , 1/sqrt(2))
equation of normal is y-1/sqrt(2)=1(x-1/sqrt(2))
y=x --- 1
The cartesian equation of the curve is cos^(-1) x=sin^(-1) y
sin y=cos x --- 2
combine 1 and 2 , sin x=cos x
tan x=0
x=0 , pi , 2pi
Since the domain is not mentioned , i take it as 0<=x<=2pi
Therefore , the normal would cut the curve at points (0,pi/2) , (pi,3pi/2), (2pi, 5pi/2)
Am i correct ?
I am confused by eq. 1 and 2. You converted (1) from cartesian to "wonky" cartesian. You have the equation of the normal line as y=x, which is correct, but that second equation seems to come out of nowhere.
What does the original function actually represent? If you graph the curve, and y=x (the normal line) the answers become more clear.
As a side note, limiting the domain might be a bad idea ;-)
ok , so how do i get the equation of the curve given its parametric equation ? I tried to eliminate the parameters and got that second equation .
Well, the curve given is a circle with radius 1.
This can be verified: The equation of a circle is
x2+y2=r2
since you were given:
x=cos(b)
y=sin(b)
x2+y2=r2 goes to:
cos2(b)+sin2(b)=r2
1=r2
1=r
If you draw the circle and the line y=x, which according to the problem is:
sin(b)=cos(b)
sin(b)/cos(b)=1
tan(b)=1
As for the intersections:
tan(b)=1=x2+y2 I think you had zero here by mistake.
If you check your unit circle, this occurs at Pi/4 +kPi, where k is an integer. (This works for all real domains, not just zero to 2Pi)
So you were on the right path from the get go, but the extra transform threw things off.
x2+y2=r2
x=cos(b)
y=sin(b)
x2+y2=r2 goes to:
cos2(b)+sin2(b)=r2
1=r2
1=r
sin(b)=cos(b)
sin(b)/cos(b)=1
tan(b)=1
thanks a tons , m.w.Clever
You're welcome, but no C in lever :) It can be tricky to visualize a lot of parametric problems, but in some cases (like this one) it really helps!
sorry to trouble you with a few more questions ,
(1) b= pi/4+kpi , is this the coordinate ? Or rather the coordinate is x=cos pi/4+kpi and
y= sin pi/4+kpi ?
because from y=x , x^2+y^2=1 , i could have solved for x and y but that's for b=pi/4 only right ?
Mark , sorry for posting on the wrong subforum coz i thought this is just a high school question .
Doesn't matter if it's high school or college or whatever. Calculus questions should go to the Calculus & Beyond section.
The line y = x comes about because the problem asks for the normal on the parametric curve at b = pi/4. This point corresponds to the point (sqrt(2)/2, sqrt(2)/2) on the circle. Because the curve is a circle, the normal to the curve intersects the circle at a point directly across the circle, at (-sqrt(2)/2, -sqrt(2)/2). The x and y values in these points are the coordinates.
