Finding the Right Delta for Epsilon-Delta Proofs
  • Thread starter Thread starter Paparazzi
    Limit Proof
4 replies · 3K views
Paparazzi
Suppose the functions [itex]f[/itex] and [itex]g[/itex] satisfy the following property: for all [itex]\epsilon > 0[/itex] and all [itex]x[/itex], [tex]\text{if } 0 < | x - 2 | < \text{sin}^2(\frac{\epsilon^2}{9}) + \epsilon, \text{then } | f(x) - 2 | < \epsilon.[/tex] [tex]\text{if } 0 < | x - 2 | < \epsilon^2, \text{then } | g(x) - 4 | < \epsilon.[/tex]
For the given [itex]\epsilon > 0[/itex] find a [itex]\delta > 0[/itex] such that, for all [itex]x[/itex], [tex]\text{if } 0 < | x - 2 | < \delta, \text{then } | f(x) + g(x) - 6 | < \epsilon.[/tex]
N/A.
Note that [tex]| f(x) + g(x) - 6 | = | (f(x) - 2) + (g(x) - 4) | \le | f(x) - 2 | + | g(x) - 4 |[/tex] by the triangle inequality.
Now, we need to find [itex]\delta_1, \delta_2 > 0[/itex] such that the two conditions [itex]| f(x) - 2 | < \frac{\epsilon}{2}[/itex] and [itex]| g(x) - 4 | < \frac{\epsilon}{2}[/itex] are satisfied.
This is where I fall short of the solution. Since I've done this problem before I (unfortunately) know what the answer should be. It appears that I just substituted in [itex]\epsilon/2[/itex] for [itex]\epsilon[/itex] in my previous solution, but I feel that it lacked rigor. Any clues as to where to go from here would be great. Thanks a lot.
Hi Paparazzi! :smile:
I appreciate your work to TeX everything nicely! :wink:
So, you need [itex]\delta_2[/itex] such that
[tex]0<|x-2|<\delta_2~\Rightarrow~|g(x)-4|<\epsilon/2[/tex]
But, for all [itex]\epsilon[/itex], you have
[tex]0<|x-2|<\epsilon^2~\Rightarrow~|g(x)-4|<\epsilon[/tex]
Thus if you make sure that [itex]\delta_2=(\epsilon/2)^2[/itex], then you will have
[tex]0<|x-2|<\delta_2=(\epsilon/2)^2~\Rightarrow~|g(x)-4|<\epsilon/2[/tex]
Now you must do a similar thing for [itex]\delta_1[/itex]...
So since the statement is true for all [itex]\epsilon > 0[/itex], that's the reason you can just substitute in what is needed (since [itex]\epsilon/2 > 0[/itex])? Thanks a bunch for the reply.
Indeed!
