Finding the time for a ball dropped from 4m
AnomalyCoder
You drop a ball (0.5kg) from a height of 4m.
How long did the ball take to hit the ground?
Acceleration = -10 due to gravity.
[tex]\Delta[/tex]x = Area Under a Velocity-Time graph.
^ In this case, it will be .5*Velocity*Time.
After that, I have no idea. I mean, how does one figure out what anything is?
All that is given is the ball weight and the height. How do you find the velocity without the time?
I just need some guidance, anyone know of a good resource that explains this topic?
Once I find the Velocity, finding time would be no problem whatsoever.
When a physics problem says "drop", it is understood that it means the initial velocity is zero.
You can look on this as a code, but it should also make sense that "throw" would be the word used if Vi[tex]\neq[/tex]0.
Are you familiar with the basic 4 equations of motion? There's heaps of info all over the web, or even just check out http://en.wikipedia.org/wiki/Equations_of_motion" .
There is one that concerns itself with distance (height), acceleration and time.
Sometimes the questions will give you redundant data to confuse you. Look at the 4 equations and see which ones use an objects mass (measured in kg).
Keep in mind that the statement asks for time, not velocity.
