Finding the Variables for f(x,y)=e^{xy}
  • Thread starter Unredeemed
    Variables
10 replies · 4K views · last reply
Unredeemed
Let f(x,y)=[itex]e^{xy}[/itex]
Variables u and v are defined by u=[itex]x^{3}[/itex]-[itex]y^{3}[/itex] , v=[itex]x^{2}+xy[/itex]
Find the values of [itex]\delta[/itex]f/[itex]\delta[/itex]u and [itex]\delta[/itex]f/[itex]\delta[/itex]v at the point where x=-1 and y=2
N/A
At first I thought that I'd have to write x and y in terms of u and v. So, I started by factorising using the difference of two cubes for u and then just taking out a factor of x for v. However, I pretty much hit a brick wall there.
And, if I can't write x and y in terms of u and v, I can't see how I could find either [itex]\delta[/itex]f/[itex]\delta[/itex]u or [itex]\delta[/itex]f/[itex]\delta[/itex]v?
N/A
Hi Unredeemed! :smile:
Do you have the chain rule for multi variable functions in your notes?
That is:
$${\partial f \over \partial u} = {\partial f \over \partial x}{\partial x \over \partial u} + {\partial f \over \partial y}{\partial y \over \partial u}$$
Edit: Oopsie. The following does not hold. See next posts.
Oh, and are you also aware of the inverse rule for derivatives?
That is:
$${\partial u \over \partial x} = \frac 1 {\partial x \over \partial u}$$
That is:
That is:
Your 'inverse rule' doesn't hold for partial derivatives. You need to invert the whole jacobian matrix to get the inverse derivatives.
Oopsie.
That's what I get for writing something as an afterthought.
@OP: Do you know what the Jacobian matrix is and how to use it?
That is:
That is:
I am aware of $${\partial f \over \partial u} = {\partial f \over \partial x}{\partial x \over \partial u} + {\partial f \over \partial y}{\partial y \over \partial u}$$
But, the issue with the "inverse rule" for partial derivatives led me to think it was unhelpful?
I have that if f(x,y)=F(u(x,y),v(x,y))
Then $$({\partial f \over \partial x} , {\partial f \over \partial y})= ({\partial F \over \partial u} , {\partial F \over \partial v}) . \begin{pmatrix} {\partial u \over \partial x} {\partial u \over \partial y}\\ {\partial v \over \partial x} , {\partial v \over \partial y}\end{pmatrix}$$
But, inverting the Jacobian matrix on the RHS only gives me $${\partial F \over \partial u} and {\partial F \over \partial v}$$ not $${\partial f \over \partial u} and {\partial f \over \partial v}$$ as required?
It's the same thing.
What you write is the proper way to write it.
The form ##{\partial f \over \partial u}## is short hand for ##{\partial F \over \partial u}##.
Ah, I see. I'd wondered about that but didn't just want to assume it!
So I've said that $$({\partial f \over \partial x} , {\partial f \over \partial y}) . \begin{pmatrix} {\partial v \over \partial y} -{\partial u \over \partial y}\\ -{\partial v \over \partial x} , {\partial u \over \partial x}\end{pmatrix}= ({\partial f \over \partial u} , {\partial f \over \partial v})$$
Is that correct?
Think I've got the answer now. Fingers crossed an algebraic error hasn't eluded me!
Thanks very much for everyone's help. Probably would have been head-scratching for hours without it.
