Finding triangle side length with only area and one side given
  • Thread starter Thread starter shirozack
    Length Triangle
27 replies · 4K views · last reply
shirozack
Misplaced Homework Thread
Given a triangle ABC, whose area is 5.5 cm square, and length of AB = 2√3 + 1 cm, find the value of length AC.
Given triangle has no special properties like isoceles etc.
Only 1 length and area of the triangle are given. Is it possible to solve such a question? thanks.
Welcome!
Are there any triangles that have two equal sides?
Consider the side AB to be the base of the triangle, then you can calculate the height of the triangle from the area. The question then is whether there are triangles with that height but with different length non-base sides. What would you say?
PS. If this is a homework problem, you need to use the homework format.
What do you mean by "doable"? A unique solution, perhaps?
Lnewqban said:
Welcome!
No there isn't, it is just a normal triangle.
Do you know the equation for the area of any triangle?
yea, but it feels like something is missing? given only 1 length and the area, is it possible to find the other length without any special properties of the triangle like isoceles, equilateral etc?
i tried 1/2 base height, 1/2 ab sin(c), sin rule, cos rule
it is just a generic normal triangle.
I mean is it solvable?
Yes, there are solutions.
How should i approach?
I tried to replace sin(a) in 1/2absinc with sin rule, trigo, area half base and they all just cancel each other out.
Area formula 1/2 ab sin(c) => 5.5 = ½ (2√3 + 1)(AC) sin(a)
Area formula half base height => ½ (2√3 + 1) h = 5.5
h = 11 / (2√3 + 1)
sin(a) = h / AC
Sin rule => h/sin(a) = AC/sin(90)
h/AC = sin(a)
Did the problem give you a specific type of triangle?
no it is just a generic normal triangle. just draw any generic triangle free hand. it looks like that.
h = 11 / (2√3 + 1)
OK, so now you know the length AB and the height of point C above the line through A, B. Try drawing some pictures of different triangles (different locations of point C). Which, if any, of those locations of point C meet your constraints?
Therefore, are you free to make it an isosceles triangle, or a right-angle one?
If not, you know that the three angles must add up to 180 degress.
Without doing any calculations, draw a triangle with a horizontal base. Now draw a horizontal height line above the triangle. How many triangles can you draw with the top vertex on the height line? Is their area different? Is the length of the sides up to the height line different?
EDIT: Or just look at the triangles in @Lnewqban's post above. The base lengths and heights are identical, so what can you say about the areas of the triangles? What about the lengths of the sides going up to the point?
ok let's assume the triangle looks like this and i simplified the values. Given AB = 4 and we found the height through area formula to be 3. I am trying to get length of DB i.e. (L) through similar triangles ratio and then solve for x through pythagoras theorem AD,CD,x. Problem is, when I tried to solve for L, the quadratic equation, it starts to hit complex numbers, which can't be right? where am i wrong? are my values not set well or is my approach wrong?
Those aren't similar triangles unless the angle at vertex C is a right angle.
You need to involve ##x## in your calculations. Otherwise, ##L## can take any value less than ##4##.
How should i approach it?
I have tried area formulas 1/2baseheight, 1/2absinc, sin law, cos law, and they all seem to just cancel each other out when i try to substitute them into solve the equations.
##L## can be anything less than ##4##. But, if you specify ##x## then you can use Pythagoras:
$$x^2 = 3^2 + (4-L)^2$$
yea i thought about pythagoras too, but how do i find L? the question only states the length of AB and the area. then it asks to find length of AC which is x in this case. i need to get rid of L somehow.
You can't find ##L##. ##L## can be anything less than ##4##. There is more than one triangle with a base of ##4## and a height of ##3##.
does it then mean that this question is not doable?
the original question is they gave the length AB as 2sqrt(3) + 1
and the area as 5.5 cm square, and was asked to find AC, expressing it in some integer b sqrt(3).
So since L can be anything , i assume this question cannot be done?
There is no unique solution for the length AC. The area and a single side length does fully specify a triangle. There must be another piece of data missing.
i see thanks everyone
