Finding two currents from magnetic force between parallel conductors
  • Thread starter Thread starter Bradsteeves
11 replies · 4K views
Bradsteeves
The magnitude of the magnetic force between two conductors 4.00m long, separated by 8.00cm is, 2.85X10^-5 N. The current in one conductor is twice the current in the other. Calculate both currents.
Given: FM = 2.85X10^-5 N
l = 4.00m
Mo = 4pie X10^-7
d = 0.08m
I2 = 2(I1)
I1 = ?
F2/l = Mo(I1)(I2)/2pie(d)
Couldnt really understand how I am supposed to find one of the currents when i don't know either of them, if i knew one i could find it easily.
Call one current [itex]I_1[/itex] and the other current [itex]I_2[/itex]
They directly told you how to relate one current to the other.
Um yes they told me but I am not sure how I am supposed to use that in the equation when i still don't know either of the actual currents. How am I supposed to set up the equation knowing one current is twice the other current?
If
[tex]F=\frac{\mu_0 I_1 I_2 l}{2 \pi d}[/tex]
and that [itex]I_1=2I_2[/itex]
can you substitute that into the equation and then solve?
Well all I can get from that is that it would be Mo2(I2)(I2)(l)/2pie(d) and the I2's would cancel out so ur left with F = Mo(2)(l)/2pie(d) but then how can i solve for I? I put in the values into that equation and did not end up with the correct answer
if [itex]I_1=2I_2[/itex] and you put that into the formula, [itex]I_2 \times I_2 =(I_2)^2[/itex]
Ok so then F=Mo(2)(I2)^2(l)/2pie(d) plug in 2.85X10^-5 for F, plug in 4pieX10^-7 for Mo, plug in 4 for l and plug in 0.08 for d. I calculated and ended up with 1.19 X10^-7, the answer is supposed to be 1.18 and 2.36
Then you plugged in the values wrongly or calculated wrong. I got close to those answers.
Make [itex](I_2)^2[/itex] the subject and then plug in the values.
Ok I tried that so its (I2)^2 on one side so it would be = to F(2pie x d)/Mo(2)(l) which still equalled 1.19X10^-7 so i don't know how or what way u used to get it
[tex]\frac{2\pi Fd}{2 \mu l}= \frac{2.85 \times 10^{-5} \times 2\pi \times 0.08}{2\times 4\pi \times 10^{-7} \times 4}[/tex]
Did you find that?
