Finding when snow started if plow travels 6 km in first hour, 3 km in second hour
  • Thread starter Thread starter playboy
52 replies · 15K views
D H said:
Almost. That is only correct if it started snowing at time [itex]t=0[/itex]. But you don't know when it started snowing. The trick is to invent some variable, call it [itex]t_0[/itex] to represent the time at which it started snowing.
I see what your saying.
Would this work:
Let [itex]t_0[/itex] = 12:00 - b
and we must solve for b?
You still haven't developed an equation for the snow height, [itex]h(t)[/itex]. You wrote [itex]h(t) = \dot h t[/itex], where [itex]\dot h[/itex] is the constant snowfall rate. This is not correct, because it yields the snow height at the onset of the storm as [itex]h(t_0) = \dot h t_0[/itex]. The height at the onset is presumably zero.
let [itex]t_0[/itex] be the time it started snowing (and this is what we wan to ultimately solve)
let [itex]\dot h[/itex] be the rate of snow fall.
then [itex]h(t) = \dot h (t-t_0)[/itex] where t>[itex]t_0[/itex].
Excellent. Now apply this result to the velocity equation, and then integrate velocity (definite integral) wrt time to get the distance traveled over some time interval.
So now we have:
[tex]\int_{12:00}^{13:00} v(t) dt = 6\text{\, km}[/tex]
[tex]\int_{13:00}^{14:00} v(t) dt = 3\text{\, km}[/tex]
[tex]v(t) = \frac{\dot V_{\text{plow}}}{w\;h(t)}[/tex]
Which gives..
[tex]v(t) = \frac{\dot V_{\text{plow}}}{w\;\dot h (t-t_0))}[/tex]
and ultimately,
[tex]\int_{12:00}^{13:00} \frac{\dot V_{\text{plow}}}{w\;\dot h (t-t_0))} dt = 6\text{\, km}[/tex]
[tex]\int_{13:00}^{14:00} \frac{\dot V_{\text{plow}}}{w\;\dot h (t-t_0))} dt = 3\text{\, km}[/tex]
And this can be broken down even further
Let d = distance
[tex]\int_{12:00}^{13:00} \frac{\d}}}{(t-t_0))} dt = 6\text{\, km}[/tex]
[tex]\int_{13:00}^{14:00} \frac{\d}}}{(t-t_0))} dt = 6\text{\, km}[/tex]
So evaluate the integrals. They should be easy, since [itex]\dot V_{\text{plow}}[/itex], [itex]w[/itex], [itex]\dot h[/itex], and [itex]t_0[/itex] are all constants.
^ Stupid latex... it's supposed to be
^ int(12,13) Distance\(t-to) dt = 6
^ int(13,14 Distance\(t-to) dt = 3
Yea...that's what I was trying to write out
Let all those constants = D
int(12,13) D\(t-to) dt = 6
=D*(ln(12-to) - ln(13-to)) = 6
=(ln(12-t0) - ln(12-to)) = 6\D
= and doing a whole bunch of math...
to = [e^(6\D)*13 - 12] \ [e^(6/D) - 1]
Similarily,
int(13,14) D\(t-to) dt = 3
= D*(ln(13-to) - ln(14-to)) = 3
Solving for to I get,
to = [e^(3\D)*14 - 12] \ [e^(3/D) - 1]
This gets VERY messy...
Would it be the same as letting the limits of the intergral be (0,1) and (1,2) instead of (12, 13) and (13, 14) ?
OK.
You have a sign error here,
int(12,13) D\(t-to) dt = D*(ln(12-to) - ln(13-to))
and similarly here,
int(13,14) D\(t-to) dt = D*(ln(13-to) - ln(14-to))
You have two equations in two unknowns, D and t0. You don't care about D. How can you eliminate that nasty "D" with one simple algebraic manipulation?
[D*(ln(12-to) - ln(13-to))] \ [D*(ln(13-to) - ln(14-to))] 6\3
= [(ln(12-to) - ln(13-to))] \ [(ln(13-to) - ln(14-to))] = 2
--> ln(12-to) - ln(13-to) = 2ln(13-to) - 2ln(14-to)
-->ln(12-to) -3ln(13-to) + 2ln(14-to) = 0
= ln[ (12-to)*(14-to)^2 / (13-to)^3 ] = 0
take e of both sides...
[ (12-to)*(14-to)^2 / (13-to)^3 ] = 1
(12-to)*(14-to)^2 = (13-to)^3
ALMOST THEIR!
You have it right and you are indeed almost there. You should easily be able to finish this off. I have to go again. Good luck.
I got 3.43
I was hopping it would come out to a really really nice number..
therefore, it strated snowing at 12-3.43 = 9:43am
That is not what I got.
The final task is to solve for zero,
[tex](12-t_0)(14-t_0)^2 - (13-t_0)^3 = 0[/tex]
Expanding,
[tex]155 - 25\;t_0 + t_0^2 = 0[/tex]
Which has solutions
[tex]t_0 = \frac {25 \pm \sqrt 5}2[/tex]
Choosing a positive radical means it started snow after noon; i.e., not a true solution. Thus
[tex]t_0 = \frac {25 - \sqrt 5}2 = 11 + \frac {3 - \sqrt 5}2 = 11.38 \approx 11\text{:}23[/tex]
I made a silly mistake and had
155 -25to +to^2 + 2 to^3 = 0 when it should have been 155 -25to +to^2 + 2
I made a mistake on my arithmetic
Why do you have 11:38 ~ 11:23? why 11:23?
D H, you really helped me thorugh this problem and I really really appreciate it...
Thank you so much for your time and patients :)
I have to admit, this was a very tough question for me...
You must be smart and have really good problem solving skills.
Thanks for the complement. BTW, 11.38 is the answer in hours. Our normal time-measuring system is not metric. We use days, hours, minutes, seconds,... 11.38 hours is about 11 hours and 23 minutes, or 11:23.
Oh I see, I should have known that,
Thank you once again for your help,
Problems like these are very very complicated (for me...and as you can see, it took me 2 days to figure it out with your help)
I really appreciate your help :smile:
