Finding √√(-x) for real x
14 replies · 3K views
hms.tech
For a real number x, √√(-x) equals :
a) +x b) -x c) complex d) pure imaginary
√-1 = i
Here is what i did:
If x is a positive real number then the answer comes out to be x^0.25 * √i (now what is square root of i equal to?)
But if x is a negative real number then the solution would be :
x^0.25
I don't know what to do next, any help would be appreciated.
Have you learned how to take the square roots of complex numbers?
do you know about the old [itex]re^{i x} = r Cos[x]+r i Sin[x][/itex]?
if so, I'd use that
If [itex](a+bi)^2= i[/itex] then [itex]a^2- b^2+ (2ab)i= 0+ 1(i)[/itex] so you must have [itex]a^2- b^2= 0[/itex] and 2ab= 1. Solve for the values of a and b.
√-1 = i
Here is what i did:
x^0.25
You mean |x|1/4.
Since this is a multiple-choice question, you should be able to deduce what the correct answer is. I hope you can see that you can rule out the first two choices, so the answer has to be complex or purely imaginary. Can you rule out one or the other?
No, can teach me that ?
It would really help me
HallsofIvy said:
If [itex](a+bi)^2= i[/itex] then [itex]a^2- b^2+ (2ab)i= 0+ 1(i)[/itex] so you must have [itex]a^2- b^2= 0[/tex] and 2ab= 1. Solve for the values of a and b.[/itex]
[itex] <br /> If [itex](a+bi)^2= i[/itex]<br /> ^^how is that TRUE ?[/itex]
if so, I'd use that
I know about that identity, but I can't figure out how would ot apply to this situation
What is the mod-arg form for i? Now, how can [tex]\sqrt{re^{i\theta}}[/tex] be simplified?
Alright, so for x=1
The answer is e^[2∏i]
Or another one, and perhaps i should have opened with this one, is 1
So the answer is probably
Complex
What do you think, am i right ?
You asked for the square root of i, didn't you? If a+ bi is the square root of i, then [itex](a+ bi)^2[/itex] is equal to i.
Alright, understood.
I have a concern however, why do I get two different answers by
Using the two methods
1.which was stated by hallsofivy
2.the one which uses Taylor series representation to represent
a complex number in e^(ix) form.
HallsofIvy said:
Well, what answers did you get?
Alright, this one is by the taylor series representation method:
i = e^(i*π/2)
so, √i = e^(i*π/4)
now representing the complex number in the form x+yi :
cos(π/4)+isin(π/4) = √i
so, the answer is 1/√2 + i1/√2
and the answer by the other method :
let i = (a + bi)^2
is exactly the same as before.
My bad on post no. 11
anyways, thanks
Of course, if x ≤ 0, then [itex]\sqrt{\sqrt{-x}\ }[/itex] is a real number.
i = e^(i*π/2)
so, √i = e^(i*π/4)
let i = (a + bi)^2
In the complex numbers, every number has two square roots.
[tex]\sqrt{i}= \frac{1}{\sqrt{2}}\pm i\frac{1}{\sqrt{2}}[/tex]
anyways, thanks
