Firing a projectile, max height + flight time
Yes, that is correct. Just make sure to keep track of the units. The final velocity should be in m/s.
future_vet
169
A projectile is fired with an initial speed of 65.2 m/s at an anmgle of 34.4 degrees above the horizontal on a long flat firing range.
Determine the max heigh reached by the prkectile, the total time in the air and the total horizontal distance covered and the velocity of the projectile 1.50 seconds after firing.
and
I am going to check the first parts now, and then continue once I am sure I am going in the right direction.
Vxo = vocos 34.5 = 65.2/0.824 = 79.1 m/s
Vyo = vosin34.5 = 65.2/0.566=115 m/s
t=vyo/g=11.7 seconds.
y=Vyot - 1/2gt^2= 675 meters maximum height.
And
y=yo + vyot - 1/2 gt^2
0 = 0 + 115t - 1/2 x 9.80 x t^2
t = 0 at initial point
t= 2 (115)/9.80 = 23.5 seonds.
Thanks!
Actually here's the third part
Range:
x = 0. ax=0, vxo= 79.1 m/s and 11.7x2 = 23.4 which is the total time for the whole "trip".
x= 79.1 x 23.4 = 1850.94 meters
For the velocity after 1.50 seconds, I have no idea how to proceed... Some help would be greatly appreciated. Thanks!
Do I use the same equation as in the previous part:
but replace 23.4 by 1.50 seconds
=> 79.1 x 1.5 = 118.7 meters ?
How about the significant figures throughout the exercise?
Thanks!
and
?? You say Vxo= vocos 34.5 but then you DIVIDE by cos 34.5? Same for Vyo. Surely the x and y components of speed can't be greater than the speed itself!
And
Thanks!
Your values for vxo and vyo are wrong. Recalculate them- multiply by the trig functions- and recalculate the rest.
Range:
Again, your value for vxo is wrong. Recalculate.
Thanks!
"x" is not the velocity, it's horizomtal distance. The velocity is the <vx, vy> vector. Since, as you said before, there is no horizontal acceleration, vx is just vxo. vy is, of course, vyo- gt.
and
Check these components: Vx0=V0*cos34.5; here you've divided!
(plus you've put 34.4 in the first line of the question!)
! How brainless.
Well, here is the correction:
Same but multiplying instead gives us 5.15 m/s and 36.9 m/s.
t= 3.77 seconds.
Then for the distance following y=Vyot - 1/2gt^2= 69.5 meters maximum height.
Then we have
0 = 0 + 36.9t - 1/2 x 9.80 x t^2
t= 2 (36.9)/9.80 = 7.5 seconds.
And finally for the range:
The time was 3.77 => 3.77 x 2 = 7.54 seconds for the whole trip
x= 5.15 x 7.54 = 38.8 meters
future_vet said:
! How brainless.
t= 3.77 seconds.
Check the x component of the initial velocity again. Other than that, I've not checked your arithmetic, but your method is correct.
future_vet said:
Then we have
Correct
x component of initial velocity is incorrect (as above)
future_vet said:
For the last question, do I replace 7.54 by 1.5 seconds to find the distance after 1.5 seconds?
Yes, but don't you want the velocity after 1.5 seconds?
Oops... It is 34.5 degrees... =/
OK, I thought as much, and that that was a typo. Did you see my above post re a mistake in the x component of the initial velocity?
Yes, thank you! It did look small. I can't believe I am making so many mistakes...
Actually, yes I need the velocity not the distance.
Do I use:
vyo- gt = the velocity
=> = 36.9m/s - 9.80 m/s^2 x 1.50 seconds = 14.85 m/s ?
I think I spent too much time on this exercise, nothing is making sense anymore and I am mixing up my numbers...
Do I use:
That gives you the y component of the velocity at the time t=1.5. Then calculate the x component of the velocity at this point.
To calculate the velocity at this point you need to find (a) the speed (i.e. magnitude of the velocity) at this point, and (b) the angle the velocity makes to the horizontal.
So, you can write the velocity v at this point to be v=(vcosθ, vsinθ), and you need to solve equations for v and θ
1. What is the formula for calculating the maximum height of a fired projectile?
The formula for calculating the maximum height of a fired projectile is:
h = (v2sin2θ)/(2g)
Where h is the maximum height, v is the initial velocity, θ is the angle of projection, and g is the acceleration due to gravity.
2. How do you find the flight time of a projectile?
The formula for calculating the flight time of a projectile is:
t = (2v sinθ)/g
Where t is the flight time, v is the initial velocity, θ is the angle of projection, and g is the acceleration due to gravity.
3. Can the maximum height of a projectile be greater than its initial height?
No, the maximum height of a projectile cannot be greater than its initial height. This is because the maximum height is reached when the vertical velocity becomes zero, and at this point, the projectile will start to fall back down towards its initial height.
4. How does changing the angle of projection affect the maximum height and flight time of a projectile?
Changing the angle of projection will affect both the maximum height and flight time of a projectile. Increasing the angle will result in a higher maximum height and a longer flight time, while decreasing the angle will result in a lower maximum height and a shorter flight time.
5. What factors can affect the maximum height and flight time of a projectile?
The maximum height and flight time of a projectile can be affected by several factors, including the initial velocity, angle of projection, air resistance, and the acceleration due to gravity. Other factors such as wind, elevation, and launch surface can also have an impact on the projectile's flight.
