Fitting a line by minimizing absolute deviation
The discussion centers on the method of minimizing absolute deviation using equations 15.7.14, 15.7.15, and 15.7.16, with a focus on the bisection method for parameter estimation. Participants clarify that both equations 15.7.15 and 15.7.16 must be utilized in tandem to find the parameter b, while a is derived from 15.7.15. The issue of identical signs in the function values during bisection is highlighted, indicating a potential problem with the initial parameter selection or the algorithm's implementation. The conversation emphasizes the importance of starting with appropriate values to ensure convergence in the bisection process.
  • Understanding of the bisection method for root-finding
  • Familiarity with minimization techniques in numerical analysis
  • Knowledge of mathematical equations and their application in optimization
  • Experience with algorithm design and debugging
  • Study the implementation of the bisection method in numerical analysis
  • Learn about optimization techniques for minimizing functions
  • Explore the implications of function behavior on root-finding algorithms
  • Review debugging strategies for algorithmic convergence issues
Mathematicians, data scientists, and software engineers involved in numerical optimization and algorithm development will benefit from this discussion.
borson
Hey guys!.
I need to use this method of minimization.
The procedure to follow is explained here:
http://es.tinypic.com/r/35mmtg0/9
However, I do not fully understand. What do I have to do?
What I got from the paper is that I only have to minimize the equation 15.7.16, by using bisection. With this I am supposed to obtain the parameter b, whilst "a" would be got by means of 15.7.15 once the former is minimized and we know the true b.
Then, do I not have to do anything with 15.7.14?
Is it correct what I stated of how to perform the method or I am mistaken?
Thank you all!
No, you have to use both equations in finding b. For each trial value of b, use 15.7.15 to find the corresponding a, then evaluate the expression in 15.7.16. Adjust the choice of b according the "bracketing and bisection" procedure and repeat.
Thanks for replying!
Then 15.7.14 is not used at all?
.14 leads to, and is superseded by, the pair .15 and .16.
Perfect. I designed the algorithm to perform it in that way. The problem is though, that the signs of Fx for the different values of b to bisect, after just one iteration, are the same!. Then no bisection step is taken. I do not understand why this is happening as 1) the function I am minimizing must have a root, 2) The interval to bisect that I am choosing contains that root. I am confused.
Thanks!
By the way. Can someone explain me what finding a root going downhill means?
And how can I minimize that function (.16) if its "y" values (I mean, fx) are all of the same sign? (they should have different sign so that bisection could be applied)
Is it possible to bisect in that case?
thank you all!
Thanks!
I'd need to see the data and some of the processing to figure out what is going wrong. Or maybe the coding?
I think the whole code would be a bit tedious to read. I have gone over it some hundred of times and there is no mistake in that.
here is the function that I have to minimize (43)
http://es.tinypic.com/r/2m2iebr/9
And here is the data. http://es.tinypic.com/r/d4l8j/9.
Altogether with the results of the bisection.
h2 is the parameter to be bisected, which in 43 is "n". (h is an array, composed by the different values that n gets during bisection)
I give a 0,1 - 400 interval to bisect, and as it is seen in the results, the three "n"s, yield the same result in the equation .16 (named Fx in my code), thus, no further bisection step is taken.
Thank you for all!
borson said:
here is the data
I cannot cut-and-paste from a screen snapshot. Please paste the data into a post as text.
Oh of course, sorry.
{0.75, 64.36 }, //Time of a turn, final space in radians
{1.383, 33.50 },
{1.5, 28.29 },
{1.7, 21.449},
{1.0, 51.36},
{0.85, 58.242 },
{1.35, 34.12 },
{1.383, 33.50 },
{1.5, 28.29 },
{1.7, 21.449},
{1.0, 51.36},
{0.85, 58.242 },
{1.35, 34.12 },
I find that to make the algorithm work you do need to start in the right ballpark.
Here are some values I got:
Code:
    b     a         sums
             15.7.16   15.7.14
-46.2 97.56  0.37       5.19
-46.4 97.76  0.37       5.27
-44   95.36 -0.93       7.09
-46   97.34 -0.78       5.24
-46.1 97.44 -0.13       5.18
-45   96.36 -0.93       6.16
-47   98.5   0.75       5.63
-45.5 96.86 -0.93       5.69
-46.5 97.86  0.37       5.3
So it is converging somewhere around b=-46.1.
Edit: I notice that it goes a bit crazy when one of the sgn() arguments is exactly zero. The recommended procedure of setting the value returned to zero does not fix it. Might be something to with the median function - that might need some tweaking. Look at b=-46.08.
Code:
    b     a         sums
             15.7.16   15.7.14
-47   98.5   0.75       5.63
which values for phi have you used? (I mean, for the second parameter to find out in equation 42) I already know its right phi value, which is 6.19
Still, using that value, my bisection does not work.
Thanks!
Thanks!
I just took the data values you posted (#10) as (x, y) pairs and applied the algorithm.
  • · Replies 26 ·
