Fluid draining from cone at 6 inches deep
7 replies · 3K views · last reply
Miike012
Fluid flows out of a cone at 3 cu ft/min. If the height of the cone is three times the radius how fast is the height of the fluid decreasing when the fluid is 6 inches deep in the middle?
1. V= ( (pi)(r^2)(h) ) / 3
2. r = h/3 thus... V = ( (pi)(h^3) ) / 27
(Set up the problem) ...
3. dv/dt = (dv/dh)(dh/dt)
4. dv/dh = ( (pi)(h^2) ) / 9
5. dv/dt = 3 cu ft/min.
6.h = 6
7.(plug into problem from line 3.)
8. 3cu ft/min = ( ( (pi)(6^2) ) / 9 )(dh/dt)
9.Final answer: dh/dt = (3cu ft/min )/( ( (pi)(6^2) ) / 9 )
***in the back of the book it says... dh/dt = 1296/(pi) in/min***
Im assuming that I have to convert 3cu ft/min somehow? and I also did something else wrong... can some one please help me...
thank you.
You have [tex]3 \frac{ft^3}{min}[/tex]. How can you convert that to [tex]x \frac{in^3}{min}[/tex]?
idk, but i did something wrong.. does anyone know
Try multiplying it by [tex]\frac{12^3}{1} \frac{in^3}{ft^3}[/tex]. You see why that would work, right?
Note: since 12^3 in^3 = 1 ft^3, you're multiplying by 1, which is allowed.
Yeah, I tryed that but the answer comes out to I think 455... not the answer the book gives... Ill try again, maybe my algebra went wrong somewhere.
Yeah, because I get the right answer through your algebra. Make sure you simplify as much as possible, though...
Miike012 said:
idk...
That would be your problem right there.
Thank you, I see what I did wrong... thanks for the help.
