Focal Length of Lens: Solving for f with Object and Image Distances
The problem involves calculating the focal length of a lens given the object distance and image distance. The object is located 26.0 cm in front of the lens, and the image is formed 1.60 cm in front of the lens on the same side as the object.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using the lens formula 1/f = 1/di + 1/do, with attempts to substitute the given distances. There is a focus on the sign convention for the image distance, with some questioning the correctness of their calculations and the acceptance of their answers by the computer.
Participants are actively exploring different calculations and interpretations of the lens formula. Some have suggested that the issue may relate to significant figures or the specific formatting required by the computer system for the answer.
There is mention of the computer being particular about accepted answers, and participants are considering how significant figures may affect the results they submit.
sp1974
The homework problem is "An object 26.0 cm in front of a certain lens is imaged 1.60 cm in front of that lens (on the same side as the object). What is the focal length (in centimeters) of this lens"
1/f = 1/di + 1/do
I tried solving based on having distance of object (do) and distance of image (di) so 1/26 + 1/1.6 = 1/f and I solved for f coming up with 1.51 cm. I also tried with -1.6 since they are on the same side coming up with -1.71 and the computer doesn't accept either
The image distance is negative (in the usual sign convention), so that is the correct approach.
so if I am understanding 1/26 + 1/-1.6 = 1/f and I should come up with -1.705 cm? It looks right but thinking the computer is being picky like my other answer
yeah its picky. I have put in 1.7, 1.71 1.705 and nothing. It does it everyonce in a while. I show teacher and all will be good. Thanks!
You might also try -1.70, that is the answer (-1.7049... cm) rounded to 3 sig figs.
Good luck!
  • · Replies 20 ·
