Linear and rotational acceleration from a single applied force
  • Thread starter Thread starter tom_backton
    Force Torque
5 replies · 2K views
tom_backton
This is a question about classic mechanics.
Let's say there is a disk in mid-air. There are only 2 dimentions, which is why it's a disk and not a ball...anyway, force is applied to the disk, exactly at the disk's top. Vector r goes from the disks center to the pint to which the force is applied, so r=(0,rx) . F=(Fx,Fy) . The torque causing rotaion is the xy plane (which is the torque vector's z component...) is equal to rx*Fy-Fx*ry . The force causes both linear and rotational acceleration. The question is how exactly I calculate them. Do I use the same force for both? If not, how do I calculate the accelerations?
hi tom! :smile:
yes, you use the same force in ∑ F = ma, to get the linear (vector) acceleration a.
tom_backton said:
anyway, force is applied at the disk's top. Vector r goes from the disks center to the point where the force is applied, so r=(0,rx) .
If the force is applied at the top then shouldn't r=(0,ry)?
F=(Fx,Fy) . The torque is equal to rx*Fy-Fx*ry.
For the initial state, since rx = 0, then only the -Fx*ry component matters for the torque component.
As mentioned above, the linear acceleration corresponds to linear force divided by mass. The rotational reaction doesn't affect the linear acceleration, but it will require that point of application of that force to move faster, to account for the power component used to increase rotational energy. (power = force x speed).
Assuming that the force is applied through the equivalent of a pin at the edge of the disk so the force can "pull" the disk as well as "push" it, and assuming the force remains constant in both Fx and Fy components, then it's path can be determined by the reaction of the disk to linear and angular acceleration. The math seems complicated, and momentum of the disk will cause it to behave somewhat like a pendulum while being accelerated.
So I use the same force F for both the linear acceleration (force F divided by mass m) and the rotational acceleration (force F cross-multiplied by r and then divided by the moment of inertia I) ? Does the same force cause the two accelerations? I just need to be sure...it's for a physics computer simulation program...
Yes … the Fs in those formulas are both called force because they are the same thing …
we'd call them something else if that didn't work! :wink:
Thanks for the help :)
