Fortran How can I search for a specific phrase in a sentence using FORTRAN?
  • Thread starter Thread starter manjurul
    Beginners Fortran
The discussion primarily revolves around the usage of the READ and WRITE commands in Fortran, as outlined in Michael Kupferschmid's "Classical Fortran: Programming for Engineering and Scientific Applications." The generalized form of the READ command is explained, highlighting that the 'unit' can range from 0-99 or be represented by an asterisk, with both 5 and * indicating standard input. The format can either be a default or specified through a FORMAT statement, which dictates how input/output is structured. Participants discuss how to ensure output values are written on the same line using the WRITE command, emphasizing the importance of the FORMAT statement for achieving this. A sample code snippet is provided to illustrate how to format output correctly. Additionally, there is a request for assistance in writing a Fortran code that reads a specific sentence from a text file and searches for the phrase "good boy," including its position in the sentence. The discussion remains focused on practical coding solutions and formatting techniques within Fortran.
manjurul
Most of the examples here are given from the following book,
Michael Kupferschmid, "Classical Fortran: Programming for Engineering and Scientific Applications", Taylor & Francis Group, 2009
The generalized form of READ command is as follows,
READ (unit, format) list
where, the value of 'unit' could be any value ranging from 0-99 or star symbol '*'. Both 5 or * means standard-in (usually keyboards). If the 'format' is *, then the format will be according to the compiler default. However if 'format' is not * , then it will refer the label of the FORMAT statement. Note that the FORMAT statement is used to specify exactly how the input/output will be. The 'list' is the list of variables to be read.
Any of the commands are used to read an input for variable A,
PHP:
READ (*,*) A
and
PHP:
READ *,A
are same commands. It means the program will take an input from standard-in (usually keyboard).
Technology news on Phys.org
For output the general forms are as follows,
WRITE (unit, format) listfor the details of 'unit', 'format' and 'list' see above.
HI,
I want to write some results in my fortran code. The way i want to get it written is the values should be written on the same line and NOT on the next line and so on...How can i achieve it bu using the write command?
Hi Nisha,
You need to use FORMAT statement and it is not difficult to do that.. you can see the following link to do that,
http://fortranmanjurul.blogspot.com/
also test the following code and see how FORMAT statement works
PHP:
         PROGRAM readonce
         REAL*8 X/1.23D0/, Y/53.0D0/
         J=37
         WRITE(6,10) J,X,Y
 10      FORMAT(1X,I3,T7,'X=',T9,F5.2,3X,T17,D8.2)
         STOP
         END PROGRAM readonce
Hope this solves your problem
I need to write a code which can read the following sentence from a text file,
"I know that he is a good boy!".
After reading it, the code has to search if the word "good boy" is there or not. Also the position number of "good boy" in the sentence (i.e. after how many character)
Kindly anyone help me
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
  • · Replies 22 ·
