Fortran format string with variable repeat count syntax
  • Topic: Comp Sci
  • Thread starter Thread starter speculater
    Error Fortran
5 replies · 6K views · last reply
speculater
1. Hello, I'm doing undergraduate research which requires the use of Fortran. I have one particle line of code that is not allowing me to compile the source. I was wonderding if someone can help?
909 FORMAT(i3,2x,<nvmax>(<nvmax>i1,2x),2x,i4)
2. Provides the error message:
../gensc.f90:289.18: Error: Unexpected element '<' in format string at (1)3. I'm not very familiar with the language yet, but I did try breaking up the code into two lines with the use of &&. I've also tried inserting spaces between all the "<" and ">". Any help would be greatly appreciated.
It is conventional to use <num> to indicate that you need to insert your own data value here. You should omit the angle brackets.
I'm speaking generally, not specifically of Fortran of which I've forgotten much.
I'm at work now, but I can't believe I didn't see this sooner! Now I'm excited to get home :-).
Thank you so much!
That didn't fix the compile error, but after reviewing all the code it appears that the line in question is never called on. I'm going to remove it and see if I can get my desired results.
nvmax looks like both the number of particular data values per line and the number of digits in each of those data values. If stuck, try 25 and see how it goes. It should be obvious if it is not a good choice for printing. I presume it's printing? :smile:
909 FORMAT(i3,2x,25(251,2x),2x,i4)
I would try
909 FORMAT(i3,2x,25(25i[/color]1,2x),2x,i4)
IOW, there is an 'i' missing in the innermost set of parentheses.
