FORTRAN incomparable ranks 0 and 1 in lambda assignment
4 replies · 5K views
The_shadow
Hi guys having a problem with my code, FORTRAN keeps stating:
lambda(k+1)=(newsum/oldsum)
Error: Incomparable ranks 0 at and 1 in assignment. The code is below:
subroutine powerit(a,b,c,E,n)
implicit none
real, intent(in) :: E
real, intent(inout) :: a(:),b(:),c(:)
!real, intent(out) :: x(:)
real,allocatable :: Phi(:),lambda(:),newsum(:),oldsum(:),d(:),x(:)
real :: phi_0,lambda_0
integer k, I, n
I = 100
phi_0 = 1
lambda_0 = 1
phi(1) = phi_0
lambda(1) = lambda_0
oldsum = phi_0
allocate(lambda(I),phi(I))
Do k = 1, I-1
d(k) = lambda(k)*E*Phi(k)
call tridiag(a,b,c,d,n,x)
Phi(k+1)=x(k)
newsum = sum(Phi)
lambda(k+1) = (newsum/oldsum)
print*, k, lambda(k+1), Phi(k+1)
oldsum = newsum
End do
deallocate(lambda)
end subroutine powerit
end module powermethord
Any ideas? Cheers guys!
You declared newsum and oldsum to be allocatable arrays, but you seem to be using them as scalar variables.
If you divide an array by an array (element by element) you get an array (in your code, of rank 1). You can't assign that to a scalar (of rank 0). That's what the error message says.
Yeah...what AlephZero said.
What you need to do is stop declaring newsum and oldsum as if they were arrays and declare them as scalars...that is all they are, that is how you are using them and you never allocated them either...so...
thanks guys, but I have played around with making newsum and oldsum scalars - however its still not working!? Any ideas. Thanks guys!
What's the problem, now? Please indicate.
Also, please include your code again...I want to see how you turned newsum from array to scalar...hopefully you did not just removed the parenthesis and left the variable name in the same place!
When including code, surround it with the
Code:
tags.
