Fourier series for piecewise odd function gives wrong pi formula
  • Thread starter Thread starter bobese
    Fourier
5 replies · 4K views · last reply
bobese
i'm new here so i didn't really know where to post this but I've been trying to solve the Fourier series for the following function for ages but have failed miserably on several occasions:
f(x) = 1 ; when -10 ≤ x < -5
f(x) = 0 ; when -5 ≤ x < 5
f(x) = -1 ; when 5 ≤ x < 10
The function appears to be odd when sketched so therefore only the sine coefficients exist which i found to be:
bn = [2/n(pi)]*[cos (n(pi)) - cos (0.5n(pi))]
This then gave the following results using a substitution of 10/2 instead of x in the sin parts multiplied by the corresponding bn coefficient:
f(x) = -[2/(pi)]*[1 - 1/3 + 1/5 - 1/7 ...]
That is then supposed to be used to find the following expression for pi:
pi = 4*(1 - 1/3 + 1/5 - 1/7 ...)
However, with my results i found the following:
pi = 2*(1 - 1/3 + 1/5 - 1/7 ...)
Can anyone help pinpoint my mistake please :(?
any help would be highly appreciated.
At x=5 the function f is discontinuous. Do you know where a Fourier series of f converges to at a point discontinuity?
unfortunately i do not ... i never was any good with anything to do with Fourier series :(
I wouldn't say that. You computed the series perfectly. It's a little technical matter:
You substituted x=10/2 in the series and in the function and equated the two. In this case f(5)=-1. However, it should be obvious that if the function was -1 for 5<x<=10 and 0 for -5 ≤ x ≤ 5 it would give the same Fourier series, but now f(5)=0.
If the function f is continuous at, then its Fourier series converges pointwise to f, but if there is a point discontinuity this is not the case. In general the Fourier series converges to [tex]\frac{f(x^+)+f(x^-)}{2}[/tex]. So in this case, at x=5 the series converges not to 0 or -1, but -1/2 which gives your factor of 2.
umm ... sorry to bother once again but when using parseval's theorem to calculate the coefficient alpha in front of pi squared for:the formula i was taught is:
(since the other terms are zero as a result of the odd function)
however, was not taught how to apply... do i just take the equation of pi found above and just square both sides then arrange for pi squared? if so the answer i got was 1/16 for the coefficient which i hope is correct :confused: it seems quite reasonable to do that since the bn terms are exactly the same as the the expression inside the sigma ... I'm not sure :confused: it's the limits of the left hand side of the second equation that has me confused since f(x) takes different values between the interval and I am not quite sure what to do with that :frown:
