Can I Successfully Freeze Dry Phosphoric Acid-Soaked Carbon at Home?
  • Thread starter Thread starter copper-head
    Acid Drying
The discussion centers on successfully freeze-drying carbonaceous material soaked in Phosphoric acid for activation purposes. The user employed a homemade vacuum chamber and a household freezer to achieve this process. Initially skeptical about the method's effectiveness due to the lack of continuous suction, the user reported success after four days, transforming the material into powder. This process is intended to enhance the carbon's surface area and porosity for further activation under inert conditions.
  • Understanding of freeze-drying principles
  • Familiarity with vacuum chamber operation
  • Knowledge of Phosphoric acid properties and handling
  • Basic skills in material activation techniques
  • Research advanced freeze-drying techniques for laboratory applications
  • Learn about the effects of Phosphoric acid on carbon materials
  • Explore inert atmosphere annealing methods
  • Investigate vacuum chamber design and optimization for home use
Chemists, materials scientists, hobbyists in home chemistry, and anyone interested in carbon activation techniques.
copper-head
Hello all.
I have carbonaceous material soaking in Phosphoric acid. I'd like to anneal it under an inert environment to activate the carbon. One method used in literature involved freeze drying the mixture and annealing it as is, as opposed to filtering or centrifuging the mixture. However, I am limited to a regular household freezer and a vacuum chamber. Does anyone have recommendations on how to achieve this with specialty tools?
Cheers
An update.
I built a small size vacuum chamber and placed the Phosphoric acid soaked material in a petri dish inside the chamber. After pumping the air out, I place the chamber in the freezer. After 24 hours there was build up of sublimated vapor in the chamber, so I pumped that out one more time and replaced the chamber in the freezer.
This is likely to fail. Here my opinion on why drying this into a powder would not work using this method: Freeze drying requires a continuous suction to extract the phosphoric acid vapors out of the chamber. This is would likely not happen using my contraption as my suction is not continuous and hence what I am doing is freezing a substance under vacuum. I'll keep at it for a few more days and update on the progress.
What are you actually trying to do ?
Well, the idea is to dry this carbon which is soaking in Phosphoric acid to obtain carbon-phosphoric acid powder to be later activated at high temperature under inert environment. This creates surface groups on the carbon as well as increases porosity.
AN Update:
Contrary to my expectations, it worked! the gooey phosphoric acid soaked material turned into powder 4 days later. If anyone is interested in the vacuum chamber schematics, let me know.
