Frictional force problem(box sliding down between two walls)
4 replies · 2K views · last reply
Kararr
The full problem is: "A 2.0kg box slides down at constant velocity between two identical walls. What is the frictional force exerted on the box by one of the walls?"
The answer I got was zero because I equated Normal force (of the wall on the box) at zero.
Am I wrong? ): Does the weight of the box press against the wall as well?
Please help ):
Since the velocity is constant, what can you say about the net force on the box?
oh so is frictional force= 20 N? What about the normal force though? Sorry a bit confused
Yes, the total friction force is 20 N.
Who cares? ;)
I can see the confusion about the normal force...
In most friction problems gravity provides a normal force. However in this problem something (unspecified) is causing the walls to press on the sides of the box creating a normal force and hence friction with them. Perhaps the box is made of rubber and is just a tight fit between the walls? Whatever the cause you don't need to care about it.
The problem isn't a problem about friction at all. It's about Newtons laws.
