From Aeon to Zeon to Zeit, simplifying the standard cosmic model
277 replies · 28K views
marcus said:
because the redshift+1 of the CMB is estimated at 1090, the temperature of the hot gas at last scattering, that emitted the ancient background light, was 2.725*1090 ≈ 3000 kelvin
A pale orange hue then :
Unfortunately the current color is off-the chart, in the radio spectrum, so we cannot compare : (
Astronomy news on Phys.org
The surface of last scattering is the color of orange sherbet
or the powder that ladies used to apply to their cheeks with powder puffs
And I was prosaically thinking of the color of an incandescent light bulb... You are a poet, marcus :smile:
Thank you, Wabbit. Let us imagine that at some distance from here our galaxy is being observed as it was during the formation of the solar system, say 4 and a half billion years ago. The giant shrews, whose pleasure it is to observe the heavens, have measured our galaxy's redshift. What do you suppose it is?
The key step, I guess, would be to form the H∞ time: 13.8 less 4.5 is 9.3 over 17.3 is 9.3/17.3.
And then we find H = coth(1.5*9.3/17.3) and solve the first equation for s3
$$s^3 = \frac{\coth(1.5t)^2 - 1}{0.4433}$$
(tanh(1.5*9.3/17.3)^(-2) - 1)/.4433 = 2.806
((tanh(1.5*9.3/17.3)^(-2) - 1)/.4433)^(1/3) = 1.4105
Imagine that large hairy things in another galaxy have built a telescope so stupendously powerful that they can see the Earth! and that they are right now looking at the Earth as it was when life first evolved, some 3.5 billion years ago. There are fossils of microbial mat that date that early.
One question might be: what color is their telescopic image of the Earth? We are used to thinking of our planet surface as mostly ocean blue---a shade I would place on the spectrum at 450 nanometers. A deep rich blue.
But what wavelength would that correspond to now, as it is received by the large hairy dwellers in the other galaxy?
wabbit said:
Good question, I get 635nm which is a rich shade of orange or orange-red. As Paul Eluard said, "The Earth is blue like an orange" : )
http://academo.org/demos/wavelength-to-colour-relationship/
http://encycolorpedia.com/ff3900
Thanks for responding! : ^) It was my introduction to the Eluard poem.
That is exactly right if the Earth is being observed as it was in year 9.3 billion, that is 4.5 billion years ago. s=1.41... and any blue light 450 nm would be stretched out to orange-red.
That academo.org wavelength interpreter is really nice. I hadn't seen anything like it. The 635 nm sample reminds me of Chinese lacquer-ware.
Still casting about for problem ideas. I changed the time-frame on this one (without adequate notice) and thus the redshift. It occurred to me to try year 10.3 billion, i.e. 3.5 billion years ago ---some of the earliest fossil evidence of life dates back that far. I picture the Earth having cooled down enough by then to be showing more blue ocean through the clouds. So it involves a new s. And a different color. I hope you have time to try that version out too, on the academo.
With Jorrie's permission, I'll copy here a piece he posted on his Blog, with some suggested edits. It sums up the simplified approach to cosmology we've been working out and exploring in this thread. So it contributes to this thread, but also I want us to be able to suggest edits, and comment. This is supposed to be introductory, is anything potentially confusing, can the wording be improved? I'll make any changes Jorrie approves, or delete this draft version if that seems better.
==draft version==
How Aeons turned into Zeons
Posted May 12, 2015 12:00 PM by Jorrie
Quite a lot has been written on this ... Blog about the standard Lambda-Cold-Dark Matter (LCDM) cosmological model and its equations. Arguably the most important equation of the model is the evolution of the expansion rate over cosmological time. In other words, how the Hubble constant H has changed over time. If one knows this function, most of the other LCDM equations can be derived from it, because it fixes the expansion dynamics.
The changing H is most simply expressed in this variant of the Friedman equation, an exact solution of Einstein's field equations for a spatially flat and perfectly homogeneous universe.
(1) H2−Λc2/3 = 8πG/3 ρ
Here H is the fractional expansion rate at time t, Λ is Einstein's cosmological constant, G is Newton's gravitational constant and ρ is the changing concentration of matter and radiation (at time t) expressed as a mass density. This density includes dark matter, but no 'dark energy', because Λ appears as a spatial curvature on the left side of the equation.
As you can check, the right-hand side gives SI units of 1/s2, also the units of H2 since it is the square of a fractional growth rate. Since Λ is a constant curvature, its SI units would be reciprocal area 1/m2 and multiplying by c2 again gives a 1/s2 quantity. Hence both sides' units agree. it is convenient to replace Λc2/3 with the square of a constant growth rate H∞2 representing the square of the Hubble constant of the 'infinite future', when cosmic expansion will effectively have reduced matter density to zero.
(2) H2−H∞2 = 8πG/3 ρ
Since we can measure the present value of H, labeled H0 (H-naught) and also how it has changed over time, it allows us to use Einstein's GR and his cosmological constant to determine the value of H∞. If we assume that radiation energy is negligible compared to other forms (as is supported by observational evidence), then we can express eq. (2) as:
(3) H2−H∞2 = (H02−H∞2)S3
H0 is the present observed rate of expansion per unit distance, which tells us that all large scale distances are presently increasing by 1/144 % per million years. This gives us a Hubble radius of 14.4 billion light years (Gly). S is the 'stretch factor' by which wavelengths of all radiation from galaxies have increased since they were emitted.[1]
Clearly the distance growth rate H is changing, it is declining and leveling out at the constant value H∞. The point of this equation is to understand how it is changing over time and how this effects the expansion history. But let's imagine that H remains constant. Then, as you can check, the size a(t) of a generic distance would increase as eHt. The time interval 1/H would then be a natural time-scale of the expansion process. In that length of time distances would increase by a factor of e = 2.718. For constant H, the time 1/H is called the e-fold expansion time. It is analogous to a "doubling time" and differs from the doubling time only by a factor of ln 2.
But in the long run the universe's expansion process will be exponential at nearly the constant rate H∞, so eventually all large scale distances will undergo an e-fold expansion every 17.3 Gy. Or stated differently, all distances will eventually grow at H∞ = 1/173 % per million years.
The 17.3 Gy 'e-fold time' is a sort of natural time scale set by Einstein's cosmological constant. An informal study by a group of Physics-Forums contributors suggested that the 17.3 Gy time-span could be a natural timescale for the universe.[2] For lack of an 'official name' for it, the group called it a 'zeon', for no other good reason than the fact that it rhymes with aeon.
One light-zeon is 17.3 Gly in conventional terms and H0 expands distances by e every 14.4/17.3 = 0.832 zeon. This makes H∞ = 1 per zeon and H0 = 17.3/14.4 =1.201 per zeon.[3] Our present time is 13.8/17.3 ~ 0.8 zeon.
We can easily normalize equation (3) to the new (zeon) scale by dividing through by H∞ (which then obviously equals 1).
(4) H2−1 = (1.2012−1)S3 = 0.443 S3
or
(5) H2 = 1 + 0.443 S3 !NB!
This remarkably simple equation forms the basis of a surprisingly large number of modern cosmological calculations, as will be discussed in a follow-on Blog entry.
Here is a graph of the normalized H over 'zeon-time', which is obviously the x-axis ...
The blue dot represents our present time, 0.8 zeon and a Hubble constant of 1.2 zeon-1. The long term value of H approaches 1.
Any questions before we proceed?
Regards, Jorrie
[1] 'Stretch factor' S = 1/a, where a is the scale factor, as used in the LightCone calculator. S is also simply related to cosmological redshift z by S=z+1.
[2] [A] group of PhysicsForums members [fleshed] out of this "universal scale", based on the cosmological constant.
[3] The traditional unit of the Hubble constant as used by Edwin Hubble is kilometers per second per Megaparsec. From an educational p.o.v. it was an unfortunate choice, because it seems to indicate a recession speed, while it is really a fractional rate of increase of distance. It is a distance divided by a distance, all divided by time. So its natural unit is 1/time, or simply time-1.
One thing which not to obvious to me is who exactly is the target audience - the write up seems to assume prior knowledge of Friedman's equation, so it seems to aim at those who have learned FLRW enough to not need a reminder of what that equation is or what it means. But on the other hand most of it is accessible to someone with no such prior knowledge - provided a brief intro is added.
That's a good idea, something that Jorrie may choose to do. It's part of what interests me about this concise layout as an example if how a section or chapter of a tutorial could go. As for the intended audience, I think Jorrie's blog readers have been exposed to Friedmann equation and LambdaCDM. So they've had an introduction of some sort and this is more giving them a glimpse of a variant version of the Friedmann equation (which has some nice featues) when they've already got some idea of the standard cosmic model. I think. don't know for sure.
I recall he started off this way:
==quote==
Quite a lot has been written on this ... Blog about the standard Lambda-Cold-Dark Matter (LCDM) cosmological model and its equations...
==endquote==
BTW Jorrie and Wabbit and whoever else might be reading,
since we decided for good reasons (I thought) to go with MASS density of matter instead of the energy density equivalent, I wanted to use our basic equation and basic parameters 14.4 and 17.3 to calculate the present-day density in familiar imaginable terms, like micrograms and a cubic volume that is 1000 km on a side. Everybody at the BBQ should be able to picture 1000 km, because we fly distances like that to visit relatives.
The basic equation, e.g. in Jorrie's blog, is
$$H^2 - H_\infty^2 = \frac{8 \pi G}{3} \rho$$
So I typed this into google
((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G)
which is
$$\rho = (H^2 - H_\infty^2) \frac{3}{8 \pi G} $$
and google gave back
((((14.4 billion years)^(-2)) - ((17.3 billion years)^(-2))) * 3) / ((8 * pi) * G) =
2.66045729 × 10-27 kg / m3
which looks to me like 2.66 micrograms in a cube which is 1000 km on a side.
So I tried to force google to tell me the answer in micrograms per cubic megameter and I typed in
((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G) in micrograms/(1000 km)^3
and the google calculator bought it and came back with
2.66045729 micrograms / ((1000 km)^3)
Google calculator. It loves to show off by putting in all the parentheses.
There should be a google calculator at every engineer's barbecue! It turns out the calculator knows "megameter"! I typed in:
((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G) in micrograms/megameter^3
and it came back with
2.66045729 micrograms / (megameter^3)
Interesting : )
Following your lead I tried ((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G) in u/m^3
Google tells me that's 1.602 atomic mass per cubic meter - I guess we can call that 1.6 hydrogen atom per cubic meter.
I also note that humans are frighteningly dense at ~10^30 times the average density of the universe. And that ratio is getting higher everyday :wink:
wabbit said:
Interesting : )
That might be even better as a way to communicate the average density. I'm glad to learn that google calculator understands the atomic mass unit "u"
As I recall if one calculates it in terms of energy density equivalent (which we've decided not to use) it comes out around 0.24 nanojoules per cubic meter.
I always liked that because it seemed communicable. Everybody knows cubic meter and you can demonstrate a joule of energy by raising a book 10 centimeters off the table and letting fall back with a little thump. 10 Newtons to raise a 1 kilogram book, by a tenth of a meter. A one joule thump.
So the universe has about 0.24 joules worth of matter in a cubic kilometer.
Justwanttoobserve that a joule of energy is something we can experience and feel and a cubic kilometer is something we can visualize so 0.24 joule per cubic km is something definite and comprehensible. But we're giving up on the energy density measure of matter concentration, for good and sufficient reasons!
How about mass density measures? a lot of people only have a foggy idea of a gram (the weight of a paperclip?), and nobody ever felt the weight of an hydrogen atom or of a microgram.
Those are more verbal ideas, rather than experiential. Still, we want to re-ify the universe's average mass density.
WE'RE IN LUCK.
In a sense we are confronted by the distance to the Sun all the time. 150 million km. If you can't already imagine a cube which is a million km on a side then maybe give it a try? Learn how? A million km is a gigameter. We're in luck because google calculator knows gigameter.
What Wabbit tried is rather beautiful (the calculator knows u, the atomic mass unit) but instead of this:
wabbit said:
Interesting : )
... I tried ((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G) in u/m^3
let's try this:
((14.4 billion years)^-2 - (17.3 billion years)^-2)*3/(8 pi G) in kg per gigameter^3
I pasted that in and google liked it and came back with:
2.66045729 kg per (gigameter^3)
That has the advantages that
We can calculate it from our two basic numbers 14.4 and 17.3
Everybody has felt the weight of a kilogram and can probably picture something with around that 2.66 kg mass (a gallon of milk from the supermarket isn't TOO far off especially if it has been in the fridge a day or so and is only 3/4 full.)
Admittedly a cubic gigameter is something of a stretch to visualize. But maybe the million km distance itself should be part of our intuitive repertory given that an AU is 150 of them.
wabbit said:
Interesting : )
I keep coming back to this. one atomic mass unit per cubic meter is a nice density. It has a classic sound.
Visualized as one hydrogen atom per cubic meter.
If I temporarily think of that as standard density, then the current density of the universe is 1.6, as you point out. or 1.602.
the word "gigameter" is clunky. But one could use it to explicate this classic standard density.
One u per cubic meter is the same as 1.66 kg per cubic gigameter.
To a trained physicist that's completely trivial because he knows that an atomic mass unit is 1.66 x 10-27 kg. But as an amateur bystander, I regularly forget such things.
Can we re-ify or "thing-ify" a million kilometers? Should we even want to?
Distance to Sun 150
Distance to our moon 0.38
Distance from Jupiter to its two largest moons: 1.07 and 1.88
Distance from Jupiter to the other two large ones: 0.42 and 0.67
Distance from Saturn to its four largest moons: 0.38, 0.53, 1.22, 3.56
Is this too Baroque? I look in the fridge and see a 3/4 full gallon of milk. I think of the distance from Saturn to its largest moon Titan. I imagine a CUBE that size. I explode the 3 quarts of milk to fill that cube and that is the average density of the universe, at present.
Or I think of the distance from Jupiter to ITS largest moon, Ganymede. That is even closer to right distance: 1.07. And base the cube on that.
I suppose it is ridiculous and doesn't quite make it. I'm using 3 quarts of milk to represent 2.66 kilograms. Taking the 1.66 of "u" and the 1.6 that Wabbit calculated, multiplying 1.6 x 1.66 to get 2.66.
2.66 x 10-27 kg per m3 = 2.66 kg per cubic gigameter
How else can I imagine a million kilometers? 2.6 times the distance to our moon?
1/150 of the distance to the sun?
How about using the Earth moon distance itself as a unit
1.6 u/m^3 in kg/(4 pi/3 (384400km)^3)
630g per sphere of earth-moon radius?
(Anything without gigameters really, I have to mentally convert them - twice to make sure - each time I see that unit:)))
Great suggestion!
I put this in google
4 pi/3 *2.6^-3*2.66 kg in pounds
and it gives me 1.4 pounds. that much butter would have to be dispersed in a sphere of earth-moon radius!
I ventured to our fridge and found approximately 1.4 pounds of butter on the shelf in the door.
Huge lasers are trained on this butter and in an instantaneous flash it is vaporized, becoming a glowing cloud
which expands to fill a sphere of earth-moon radius.
This is the current density of the universe.
Somwhere along this thread we went from natural, universal units based on the cosmological constant and the Planck length, to pounds of butter per moon-sphere... next week we'll show you how to cook a universe in your microwave (oven, not background) :wink:
There's a real tension, even if we both joke about it. I think H∞ is a great unit and when you use it the equations do simplify nicely.
From that unit rate of fractional growth we get an e-fold time unit of 17.3 billion years.
That's an awful mental stretch.
Or maybe it's not. Maybe one just adopts the right perspective, the present Age is 0.8 zeon, the present distance growth rate is 1.201 per zeon, and everything is nice.
I've gotten side-tracked, in a way, worrying about how to make that huge (lovely) time unit palatable.
The business about matter density is merely a minor distraction. Rho is just a footnote.
How much fuss do you think needs to be made about assimilating the zeon time unit?
Do we break it down into billionths and practice imagining and remembering passages of "zeits" of 17.3 years? Talk about H∞ as fractional growth of one billionth per zeit?
Or just present the main unit with a blank stare and count on some readers being sophisticated enough to find, if they care to, their own private ways to assimilate it.
Wabbit, do you have some ideas about how to communicate the fact that an instantaneous fractional growth rate of 1/zeon does not correspond to a doubling time of 1 zeon?
Because of compounding the doubling time is actually ln2 zeon. It is shorter than the e-fold time by a factor of ln 2 = 0.693.
Maybe one just states this? Or offers a brief explanation like:
$$a(t) = e^{\frac{1}{zeon}t}$$
$$a(zeon) = e^{\frac{1}{zeon}zeon} = e^1 = 2.718...$$
If that turns out to be sufficient, it removes one of my concerns that led to proposing a billionth unit.
I was motivated to suggest a nanozeon or zeit unit because it is short enough that one can neglect the effect of compounding and say straight out that, with H∞ = a billionth per zeit, a typical distance grows by one billionth of its size in one zeit.
About the zeon or zeit unit, I think.since most people have some familiarity about the age of the universe already, and about the timescale of earth, geology, life evolution, these would be good references - Earth is about 0.3 zt old etc. One issue is that I think.its easier to grasp units when things are measured as a few to.a few thousand units, rather than a fraction of a unit - we could introduce millizeits but that would be one more unit again.
##H_\infty=1## is a bit hard to get as a fractional growth rate, not sure how to get around this. A growth rate of 1 is just not directly apprehensible.
As to e-folds, it is natural because of the exponential function - this reminds me of the questions asked in another thread, and somehow the key seemed to be ##(1+x/n)^n\rightarrow e^x##.
So ##H_\infty=1## means that in the distant future distances will grow by 1 percent for each percent of a zeit.
But this doesn't help much wrt to doubling time... is it really necessary to introduce doubling time?
Probably we don't have to introduce doubling time. It sounds like you agree with Jorrie about "zeit" He indicated, if I remember, that he liked zeit as a name for the main unit, instead of zeon.
I had come up with zeit as a provisional name for a billionth of the main time unit. Jorrie said he didn't like changing units and would go with whatever we had rather than start renaming but if we had to do it over he would favor zeit and if you need a billionth of that just call it "nanozeit".
I'm of a mind to follow your and Jorrie's leanings on this. You say make main unit "zeit" and suggest abbreviation "zt" and the present age is 0.8 zt.
Jorrie suggested abbreviation nz for nanozeit.
To paraphrase your above post, H∞ = 1 means that in the distant future distances will grow by 1 ppb per nz.
That is by one part per billion every nanozeit.
Also noting what you said about people finding it easier to grasp fractions and multiples on the order of 0.001 and 1000 or even closer to one than that. I'll try out a thousandth.
To paraphrase again, H∞ = 1 means that in the distant future a distance will grow by a thousandth of its size each millizeit.
That is 0.001 per mz.
In Earth orbit terms, one mz is 17.3 million years. OK, I can kind of picture that. they had wooly mammoths back then, didn't they? Warm-blood hairy things faintly resembling ourselves in many respects.
Heck, it was just a millizeit ago!
Maybe this is going to be all right. From Aeon to Zeon to zeit.
zeit should not be capitalized, that way it's less apt to be confused with the capitalized German noun.
Actually it wasn't conscious choice I was following what I thought you had more or less settled on - but I do agree, either zeit or zeon is fine but I think its better if that one unit designates directly a natural value such as ## H_\infty=1 ##.
Nothing wrong with nanozeit but isn't that a bit small ? millizeit would give nice results for geological ages with ~230 millizeits for the age of the earth. Or maybe microzeit ? Andromeda is about 0.1 microzeit away and it is not part of the Hubble flow, I guess that might starts at microzeit scale (or a bit higher ?) so maybe ~1 microzeit is about the smallest "cosmological" distance.
I see the point you are making about geological ages and millizeits. It's actually a convenient scale
http://en.wikipedia.org/wiki/Age_of_the_Earth
4.54/17.3 Basically the age of the earth, given there, is 260 mz.
Let's see what some geological ages look like in millizeits.
This is from UC Berkeley Museum of Paleontology, I think it is part of their public outreach educational website. http://www.ucmp.berkeley.edu/education/explorations/tours/geotime/guide/geologictimescale.html
The Cambrian would be how many millizeits ago?
543/17.3 = 31
OK, 31 millizeits ago there were a lot of trilobites and fish got started.
and then 29 millizeits ago the first land plants
and then 25 mz ago there were insects and fish developed jaws
and 24 mz ago *amphibians*, like frogs! and a whole lot of fish!
and 21 mz ago insects developed wings and there were forests
and 19 mz ago, the first reptiles, and really big forests
and 17 mz ago, amphibians were dominant, but later there was a major extinction over land and sea.
Then 14 mz ago, first dinosaurs, also (according to one definition) first mammals.
12 mz ago, dinosaurs dominant, first birds appear
8.4 mz ago, marsupials, bees, butterflies, flowering plants, then a mass extinction esp. of large animals.
3.8 mz ago, *placental mammals*, modern birds, first primates (things with thumbs)
3.1 rodents, primitive whales, grasses
2.2 pigs, cats, rhinos
1.3 dogs and bears---insects and flowering plants coevolve
0.3 millizeit ago, first hominids
The Wikipedia article on Mammals allows for several definitions including one that puts the first mammals around 167 million years ago or roughly 10 mz. (the most recent common ancestor of all extant mammals--a "clade"-type definition.)
http://en.wikipedia.org/wiki/Mammal#Varying_definitions.2C_varying_dates
"Clade" (phylogenetic) classification has gained adherents over recent decades so maybe one wants to go with that and say the mammal clade started around 10 millizeit ago. "Crown group" is a technical term in cladistics, not a term of approbation. A set of species for which one is going to find the most recent common ancestor.
http://en.wikipedia.org/wiki/Crown_group
==quote Mammal article==
If Mammalia is considered as the crown group, its origin can be roughly dated as the first known appearance of animals more closely related to some extant mammals than to others. Ambondro is more closely related to monotremes than to therian mammals while Amphilestes and Amphitherium are more closely related to the therians; as fossils of all three genera are dated about http://tools.wmflabs.org/timescale/?Ma=167 million years ago in the Middle Jurassic, this is a reasonable estimate for the appearance of the crown group.[6]
==endquote==
That said, I don't think there is any need for us to get off topic and onto geology/paleontology. I wanted to do two things (1) pick up on your comment suggesting millizeit could be a good scale for geological ages (thus giving people a way to get used to and assimilate that scale: something to practice on.) and
(2) try it out, myself, to see how well the scale worked.
It seems to work OK.
I think this is the ZEIT thread now. Jorrie first suggested doing away with "zeon" and it has taken me a while to come around to that. I'm not sure why but zeit just seems to sound better and it's one syllable: easier to say.
Jorrie said:
'Zeit' is actually a very cute choice, because it is German for 'time'; pity we did not originally hit upon it instead of 'zeon'...
My conservative choice would be to do away with zeon and replace it with 'zeit' and then use 'nanozeit' (or simply nz) for the 17.3 years period (only one new name)...
marcus said:
Your mentioning blogs led me to find the 12 May blog entry where you gave a presentation of the cosmic model using H∞ units. I hadn't seen it earlier because I was looking only for discussion board posts. It's clear and succinct. I'd like to copy it in the AeonZeon thread. It would fit into one medium sized post, I think. Let me know if that would be undesirable for any reason.
Jorrie said:
BTW, if you want to copy my humble Engineering Blog post here, you are welcome. Edit as you think necessary.
marcus said:
I added it to the AeonZeon thread (tinkered with the wording some, couldn't resist : ^)
Let me know if unsatisfactory for any reason. I can change or delete as you wish.
https://www.physicsforums.com/threa...ndard-cosmic-model.811718/page-4#post-5134159
I want to recopy Jorrie's brief blog summary putting in zeit and see how it looks.
===tinkered with copy, putting in zeit for zeon===
==draft version==
How Aeons turned into Zeits
As you can check, the right-hand side gives SI units of 1/s2, also the units of H2 since it is the square of an instantaneous fractional growth rate. Since Λ is a constant curvature, its SI units would be reciprocal area 1/m2 and multiplying by c2 again gives a 1/s2 quantity. Hence both sides' units agree. it is convenient to replace Λc2/3 with the square of a constant growth rate H∞2 representing the square of the Hubble constant of the 'infinite future', when cosmic expansion will effectively have reduced matter density to zero.
Clearly the distance growth rate H is changing, it is declining and leveling out at the constant value H∞. The point of this equation is to understand how it is changing over time and how this effects the expansion history. But let's imagine that H remains constant. Then, as you can check, the size a(t) of a generic distance would increase as eHt. The time interval 1/H would then be a natural time-scale of the expansion process. In that length of time distances would increase by a factor of e = 2.718. For constant H, the time 1/H can be called the "e-fold time", by analogy with "doubling time" . An e-fold is like a doubling except by a factor of 2.718 instead of 2.
In the long run the universe's expansion process will be exponential at nearly the constant rate H∞, so eventually all large scale distances will undergo an e-fold expansion every 17.3 Gy. Or stated differently, all distances will eventually grow at about H∞ = 1/173 % per million years.
The 17.3 Gy 'e-fold time' is a natural time scale set by Einstein's cosmological constant. An informal study by a group of Physics-Forums contributors suggested that the 17.3 Gy time-span could be a natural timescale for the universe.[2] For lack of an 'official name' for it, the group called it a 'zeit'. The longterm expansion rate, the reciprocal of the e-fold time, is therefore H∞ = 1 per zeit.
One light-zeit is 17.3 Gly in conventional terms. If the current rate H0 were to continue unchanged, distances would expand by e every 14.4/17.3 = 0.832 zeit. H0 = 17.3/14.4 =1.201 per zeit.[3] Our present time is 13.8/17.3 ~ 0.8 zeit.
We can easily normalize equation (3) to the new (zeit) scale by dividing through by H∞ (which then obviously equals 1).
or
Here is a graph of the normalized H changing over time, expressed in zeits.
The blue dot represents our present time, 0.8 zeit and a Hubble constant of 1.2 zeit-1. The long term value of H approaches 1.
marcus said:
With Jorrie's permission, I'll copy here a piece he posted on his Blog, with some suggested edits. It sums up the simplified approach to cosmology we've been working out and exploring in this thread. So it contributes to this thread, but also I want us to be able to suggest edits, and comment. This is supposed to be introductory; is anything potentially confusing, can the wording be improved? I'll make any changes Jorrie approves, or delete this draft version if that seems better.
Marcus, I'm happy with using this as a 'development platform' for a simplified introduction to cosmology. It needs some development, because I'm not happy with my own writing on it. It feels like 'full of holes' in terms of clarity.
It also received a completely underwhelming response on my Engineering Blog. Generally, engineers don't like reading equations that do not fit into their daily-use regime. They then want to read text in their own lingo that tells them exactly what an equation is 'trying to tell' them, without having to puzzle it out themselves. Almost (but not quite) 'barbeque ("braai") level'.
I'm not sure to what degree this holds for physicists as well (?)
However, I think we may be able to find common ground and so serve both communities...
