fsolve error with more than 5 equations in MATLAB
  • Context: MATLAB
  • Thread starter Thread starter cianfro1
    Matlab
6 replies · 28K views
cianfro1
I'm trying to solve a system of non-linear equations. I was successful in solving 5 equations/5unkowns with the function fsolve. However, when I have more than 5, I get the error message:
? Attempted to access r(17); index out of bounds because numel(r)=5.
How do I increase that size so that I can solve for 20 equations, instead of a mazimum of 5?
It seems as if there isn't a limit.
For fsolve, the nonlinear system of equations cannot be underdetermined; that is, the number of equations (the number of elements of F returned by fun) must be at least as many as the length of x ...
Furthermore, it's not listed as a limitation:
Limitations
The function to be solved must be continuous. When successful, fsolve only gives one root. fsolve may converge to a nonzero point, in which case, try other starting values.
fsolve only handles real variables. When x has complex variables, the variables must be split into real and imaginary parts.
I'm not familiar with MATLAB... are you sure your "r" variable is the correct size/datatype, to hold a value at index 17? And are you sure that you've correctly specified all 20 some functions?
the 'r' variable is not the problem. Even if I do a test system of equations with 6 equations, it has the same problem. There must be some default that will only solve for 5 equations. If that is the case, I can't find out how to change it.
As I understand it, the 'r' variable is precisely the problem. There's a read error when trying to access r(17), which means r(17) does not exist. The length of r is 5.
Whether or not that is a restriction imposed by fsolve, I'm not sure. But I'd assume it's not a limitation, since it's not listed as one under the documentation. Furthermore, searching for this problem on Google yields absolutely nothing of any relevance.
If it is a limitation, they should update their documentation. Otherwise, try posting your code here. Maybe someone can spot some error in your code.
Actual Code of Problem
function z = wsteady(r,Et,Ti,Ta,Tdp,v,sigma,absorb,Fe,emiss,Wf,Rfb,Rfins,vamb,Dh,L,P,A,Ub,Uins,hi,density,mdot)
z(1) = r(1) - (0.75*r(17) + 0.25*Ta);
z(2) = r(2) - ((Ta-273)*(0.8004 + 0.00396*(Tdp-273))^0.25 + 273);
z(3) = r(3) - (1006+0.05*(r(1)-273));
z(4) = r(4) - ((0.09485*(r(1) - 273) + 13.278)/1000000);
z(5) = r(5) - ((0.02795*(r(1) - 273) + 24.558)/1000);
z(6) = r(6) - (v*Dh/r(4));
z(7) = r(7) - (r(4)*r(3)*density/r(5));
z(8) = r(8) - (sigma*Fe*(r(16)^4-r(18)^4)/(r(16)-r(18)));
z(9) = r(9) -(0.5*sigma*emiss*(r(15) ^4-Ta^4)/(r(15) -Ta));
z(10) = r(10) - (0.3535*sigma*emiss*(r(15) ^4-r(2)^4)/(r(15) -r(2)));
z(11) = r(11) - (0.1465*sigma*emiss*(r(15) ^4-Ta^4)/(r(15) -Ta));
z(12) = r(12) - (2.537*Wf*Rfb*(P*vamb/A)^0.5 + 1.31*(abs(r(15) - Ta))^(1/3));
z(13) = r(13) - (Rfb*r(5)/Dh*(5.4 + 0.00190*(r(6)*r(7)*Dh/L)^1.71/(1 + 0.00563*(r(6)*r(7)*Dh/L)^1.17)));
z(14) = r(14) - (Rfins*r(5)/Dh*(5.4 + 0.00190*(r(6)*r(7)*Dh/L)^1.71/(1 + 0.00563*(r(6)*r(7)*Dh/L)^1.17)));
z(15) = absorb*Et - (r(12)*(r(15) -Ta) + r(9)*(r(15) -Ta) + r(10)*(r(15) -r(2)) + r(11)*(r(15) -Ta) + Ub*(r(15) -r(16))); % + bden*br(3)*bvol*(r(15)-Tref)
z(16) = Ub*(r(15) -r(16)) - (r(13)*(r(16)-r(1)) + r(8)*(r(16)-r(18)));
z(17) = mdot*r(3)*(r(17)-Ta) - (r(13)*(r(16)-r(1)) + r(14)*(r(18)-r(1)));
z(18) = r(8)*(r(16)-r(18)) - (Uins*(r(18)-r(19)) + r(14)*(r(18)-r(1)));
z(19) = Uins*(r(18)-r(19)) - (hi*r(19)-Ti);
I recall the function using the following code:
sigma = 5.67e-8;
absorb = 0.8;
emiss = 0.9;
Fe = 0.82;
Etwinter=900;
Ti = 296;
Tawinter=268;
Tdpwinter=263;
Wf = 1;
vamb=2;
absorb = 0.8;
sig = 0.0000000567;
emiss = 0.9;
Fe = 0.82;
L=1.8288;
W=0.8128;
gap = 0.0254;
A = W*L;
Dh = 2*gap;
P = 2*W + 2*L
Rfb = 1.67;
Rfins = 2.17;
Uins = 0.283;
Ub = 13.4;
hi = 8.29;
vwinter = 0.8;
densitywinter = 288.15/Tawinter*1.2255;
mdotwinter = densitywinter*gap*vwinter;
options=optimset('FunValCheck','on');
x0=[290,287,288,297,296];
winter = fsolve('wsteady',x0,options,Etwinter,Ti,Tawinter,Tdpwinter,vwinter,sigma,absorb,Fe,emiss,Wf,Rfb,Rins,vamb,Dh,L,P,A,Ub,Uins,hi,densitywinter,mdotwinter);
<snip>
The array x0 has 5 elements and that is passed to the function wsteady as the variable r. So, as Sane said above, the length of array x0 should at least be as long as the variable r used in the function (which is 19 elements I believe).
wow... i overlooked the initial guess. The code was edited from 5 equations to 19 and i forgot to change that part! You guys were both right. Thank you very much!
