Function Field over k --> k(x) - Rotman Definition and Proposition 3.29
4 replies · 2K views
Math Amateur
MHB
I am reading Joseph J. Rotman's book: A First Course in Abstract Algebra with Applications (Third Edition) ...
I am currently focused on Section 3.3 Polynomials ...
I need help with an aspect of the proof of Proposition 3.29 concerning elements of the function field $$k(x)$$.
Rotman's definition of a function field over $$k$$ and his Proposition 3.29 and its proof read as follows:View attachment 4695
In the proof of Proposition 3.29 displayed above, we read the following:
" ... ... elements in $$k(x)$$ have the form $$f(x) {g(x)}^{-1}$$ ... ... "I am perplexed by the above statement as it includes the polynomial $${g(x)}^{-1}$$ and I thought the only inverses in $$k[x]$$ were the constant polynomials ... and that no other inverses existed in $$k[x]$$ ... so how are we to make sense of the above statement ... unless we just regard $$f(x) {g(x)}^{-1}$$ as the result of $$f(x)$$ divided by $$g(x)$$ ...
Can someone please clarify the above issue ...
Peter
Let's consider the rationals $\Bbb Q$, the fraction field of $\Bbb Z$. Its elements are represented in the form $m/n$, where $m\in \Bbb Z$ and $n\in \Bbb Z \setminus \{0\}$. Based on your reasoning, $1/n$ (or $n^{-1}$) is an integer. See where the problem is? Certainly, $1/2$ is not an integer. In fact, $1/n$ is only an integer for $n = \pm 1$.
Recall that $k(x)$ isn't IN $k[x]$, it's "bigger".
Specifically, $k(x)$ is an equivalence over $k[x] \times (k[x] - \{0\})$, and $\dfrac{1}{g(x)}$ refers to the equivalence class of the pair:
$(1,g(x))$.
In $k(x)$ this is indeed a multiplicative inverse for $g(x)$ (which is identified with the equivalence class of $(g(x), 1)$ because the identification:
$f(x) \mapsto [(f(x),1)]$ is indeed an injective ring-homomorphism)
and the multiplication in $k(x)$ is given by:
$[(a(x),b(x))]\cdot[(c(x),d(x))] = [(a(x)c(x),b(x)d(x))]$, so:
$[(1,g(x))]\cdot[(g(x),1)] = [(g(x),g(x))] = [(1,1)]$.
(Recall that $[(a(x),b(x))] = [(c(x),d(x))]$ if and only if $a(x)d(x) = b(x)c(x)$, and surely $g(x)\cdot 1 = 1 \cdot g(x)$).
It is sometimes "easier" to visualize $\dfrac{1}{g(x)}$, as the function:
$f: K - S \to K$, where $S = \{a \in K: g(a) = 0\}$. given by:
$f(c) = \dfrac{1}{g(c)}$
Typically, when $K = \Bbb R$, these rational functions have vertical asymptotes at the zeroes of $g$.
For example, for $g(x) = x$, we get the hyperbola $y = \dfrac{1}{x}$, which has a vertical asymptote at $x = 0$ (Note this functions is NOT a polynomial function, for polynomial functions are defined at every point of $\Bbb R$).
$(1,g(x))$.
Euge, Deveno
Thanks for the help ...
Still reflecting and to an extent puzzling over this ...
I think that you are both saying that a nonconstant polynomial g(x) does not have an inverse in k[x] but does have an inverse in k(x) ... namely the equivalence class of (1, g(x) ) ... is that correct?
Peter
Yes, in exactly the same an integer $n$ does not have an inverse in the integers, but has one in the rationals.
Recall that in the rationals "fractions" are NOT unique:
$\dfrac{1}{2} = \dfrac{2}{4} = \dfrac{3}{6} =\cdots$ etc.,
but that all of these fractions have the same RATIO as each other, and it is this ratio that is captured by the equivalence class.
I urge you to read the "mathematics" section in this link, to better appreciate what this means:
https://en.wikipedia.org/wiki/Eudoxus_of_Cnidus
