Fusion reaction (don't know what I'm doing wrong)
This discussion focuses on the mechanics of fusion reactions, specifically the reaction between hydrogen and deuterium to form helium-3 and a gamma ray. The participants detail the calculations necessary to determine the kinetic energy of the reaction products, emphasizing the importance of using precise constants, such as the speed of light (2.9979e8 m/s) and the charge of a proton (1.6022e-19 coulomb). A common error identified was the incorrect addition of potential energy to kinetic energy, which led to an incorrect final answer for the kinetic energy of the reaction products.
  • Understanding of nuclear fusion processes
  • Familiarity with kinetic and potential energy equations
  • Knowledge of significant figures in scientific calculations
  • Basic grasp of particle physics, including protons and deuterons
  • Study the principles of nuclear fusion and its applications in astrophysics
  • Learn about the conservation of energy in nuclear reactions
  • Explore the use of significant figures in scientific calculations
  • Investigate the role of gamma rays in nuclear reactions
Students studying physics, particularly those focusing on nuclear physics and energy conservation, as well as educators seeking to clarify fusion reaction concepts.
tkoi
In a fusion reaction, the nuclei of two atoms join to form a single atom of a different element. In such a reaction, a fraction of the rest energy of the original atoms is converted to kinetic energy of the reaction products. A fusion reaction that occurs in the Sun converts hydrogen to helium. Since electrons are not involved in the reaction, we focus on the nuclei.
Hydrogen and deuterium (heavy hydrogen) can react to form helium plus a high-energy photon called a gamma ray:
[tex]^1H + ^2H \rightarrow ^3He + \gamma[/tex]
Objects involved in the reaction:
Code:
Particle        # of protons    # of neutrons    Charge    Rest Mass (atomic mass units)
[sup]1[/sup]H (proton)     1               0                +e        1.0073
[sup]2[/sup]H (deuterium)  1               1                +e        2.0136
[sup]3[/sup]He (helium)    2               1                +2e       3.0155
gamma ray       0               0                0         0
Although in most problems you solve in this course you should use values of constants rounded to 2 or 3 significant figures, in this problem you must keep at least 5 significant figures throughout your calculation. Problems involving mass changes require many significant figures because the changes in mass are small compared to the total mass. In this problem you must use the following values of constants, accurate to 5 significant figures:
Code:
Constant                  Value to 5 significant figures
c (speed of light)        2.9979e8 m/s
e (charge of a proton)    1.6022e-19 coulomb
atomic mass unit          1.6605e-27 kg
[tex]\frac{1}{4 \pi \epsilon_0}[/tex]                      8.9875e9 N·m[sup]2[/sup] /C[sup]2[/sup]
A proton (1H nucleus) and a deuteron (2H nucleus) start out far apart. An experimental apparatus shoots them toward each other (with equal and opposite momenta). If they get close enough to make actual contact with each other, they can react to form a helium-3 nucleus and a gamma ray (a high energy photon, which has kinetic energy but zero rest energy). Consider the system containing all particles. Work out the answers to the following questions on paper, using symbols (algebra), before plugging numbers into your calculator.
The deuterium nucleus starts out with a kinetic energy of 1.38e-13 joules, and the proton starts out with a kinetic energy of 2.77e-13 joules. The radius of a proton is 0.9e-15 m; assume that if the particles touch, the distance between their centers will be twice that. What will be the total kinetic energy of both particles an instant before they touch?
[tex]K_{1_H} + K_{2_H} =[/tex] 2.86826e-13 joules (I got this one right)
What is the kinetic energy of the reaction products (helium nucleus plus photon)?
[tex]K_{He} + K_{\gamma} =[/tex] ________ joules
[tex]E_f = E_i + W[/tex]
[tex]W = -\Delta U = U_i - U_f[/tex]
[tex]E = m c^2 + K[/tex]
[tex]U_{elec} = \frac{1}{4 \pi \epsilon_0} \frac{q_1 q_2}{r}[/tex]
For the first question, which I got right:
[tex]E_f = E_i + U_i - U_f[/tex]
[tex]E_f + U_f = E_i + U_i[/tex]
[tex]K_{1,f} + K_{2,f} + m_1 c^2 + m_2 c^2 + U_f = K_{1,i} + K_{2,i} + m_1 c^2 + m_2 c^2 + U_i[/tex]
[tex]K_{1,f} + K_{2,f} + U_f = K_{1,i} + K_{2,i} + U_i[/tex]
The particles start out 'far apart' so Ui = 0
[tex]K_{1,f} + K_{2,f} = K_{1,i} + K_{2,i} - U_f[/tex]
[tex]= 2.77 \times 10^{-13} + 1.38 \times 10^{-13} - \frac{1}{4 \pi \epsilon_0} \times \frac{e \times e}{2 \times 0.9 \times 10^{-15}}[/tex]
[tex]= 2.86826 \times 10^{-13}[/tex]
The second question:
[tex]K_3 + K_\gamma + m_3 c^2 + m_\gamma c^2 + U_f = K_2 + K_1 + m_2 c^2 + m_1 c^2 + U_i[/tex]
Gamma ray has 0 mass and 0 charge, so
[tex]K_3 + K_\gamma + m_3 c^2 = K_2 + K_1 + m_2 c^2 + m_1 c^2 + U_i[/tex]
[tex]K_3 + K_\gamma = K_2 + K_1 + m_2 c^2 + m_1 c^2 - m_3 c^2 + U_i[/tex]
[tex]= K_2 + K_1 + c^2 (m_2 + m_1 - m_3) + \frac{1}{4 \pi \epsilon_0} \times \frac{e \times e}{r}[/tex]
[tex]= 1.38 \times 10^{-13} + 2.77 \times 10^{-13} + c^2 (m_2 + m_1 - m_3) + \frac{1}{4 \pi \epsilon_0} \times \frac{e \times e}{2 \times 0.9 \times 10^{-15}}[/tex]
Here remember that mn = (rest mass) * (atomic mass unit)
[tex]= 1.34905 \times 10^{-12}[/tex]
My homework is submitted online, and this answer is wrong. I don't know where I messed up, I did exactly what I did for the first question which I got right. Any help is appreciated.
You added the potential energy when the proton and deuteron nearly touch to the kinetic energy when they are still far apart to get the initial energy.
Ah! Of course it was something that simple. Sometimes I guess you just need a fresh pair of eyes to see what went wrong. Thanks a lot!
