Galaxy Clusters & Superclusters: Definition or Ad-Hoc?
The discussion centers on the definitions of galaxy clusters and superclusters, exploring whether these terms are rigorously defined or if they are identified in an ad-hoc manner. The conversation touches on concepts related to gravitational binding, cosmological expansion, and the implications of dark energy.
  • Some participants propose that galaxy clusters are defined as gravitationally bound groups of galaxies, while superclusters are groups of galactic clusters, with gravitational attraction being a key factor in their definition.
  • Others argue that the term "repulsive effects" can be used to describe cosmological expansion, although this usage is debated, particularly regarding its implications for the growth of structures like galaxy clusters.
  • A participant challenges the notion that cosmological expansion should be characterized as a repulsive effect, suggesting that it is more about the nature of motion in an expanding universe rather than an external force acting against gravity.
  • There is a discussion about the semantics of terms like "repulsion" in cosmology, with some suggesting that while technically incorrect, such terms can help convey intuitive understandings of physical processes.
  • Some participants assert that the definitions of galaxy clusters and superclusters are not ad-hoc, while others maintain that they lack rigorous standards.
Participants express differing views on whether the definitions of galaxy clusters and superclusters are rigorous or ad-hoc. There is no consensus on the characterization of cosmological expansion as a repulsive effect, with ongoing debate about the semantics and implications of this terminology.
The discussion reveals limitations in the definitions and assumptions regarding gravitational binding and the effects of cosmological expansion, as well as the potential confusion introduced by terms like "dark energy" and "repulsive effects." These aspects remain unresolved within the conversation.
nicksauce
Is there a rigorous definition for what constitutes a galaxy cluster or a super cluster, or are they just identified in an ad-hoc manner?
Space news on Phys.org
Galactic clusters are gravitationally bound groups of galaxies. Gravitationally bound means their mutual gravitational attraction surpasses the repulsive effects of cosmological expansion [at least for the forseeable future]. Superclusters are gravitationally bound groups of galactic clusters. Again, their gravitational attraction appears to at least slow the effects of cosmological expansion. This is, however, an interesting question. See, for example:
"The Influence of the Cosmological Expansion on Local Systems"
http://www.iop.org/EJ/article/0004-637X/503/1/61/36143.text.html
Cosmic expansion is not a replusive effect. You can call "dark energy" a repulsive effect; but it is far too small to be of much significance on the scale of a cluster.
The proper definition of "gravitationally bound" is that the velocities of galaxies in the cluster is insufficient to escape gravitational attraction. It is precisely the same definition as used to tell whether a comet is gravitationally bound to the Sun.
Cheers -- sylas
PS. The paper you cite does not back up your proposed definition of gravitationally bound. What it does is say that the effects of expansion are not significant on the scales of a cluster, or less.
Hi Sylus, what's wrong with saying cosmological expansion has "repulsive effects"? Expansion (with Dark Energy or without) is important and inhibits the growth of structure like galaxy clusters. As long as one doesn't associate "repulsion" with "force" it seems as good a word as any to describe what's going on.
-bombadil
-bombadil
Replusive effect suggests something driving the expansion, whereas this is not a necessary part of expansion at all.
Dark energy confuses the issue, because, it is a "repulsive effect" that accelerates expansion (makes things expand more). But even before dark energy was a part of the standard model, we still have expansion. The difference is that a few decades ago, the questions were centered on the idea that the universe was slowing down in the expansion... and that means the "effect" is not repulsive at all, in any way. It is attractive. The effect considered was gravity and mutual attraction of massive objects... which SLOWS DOWN expansion as it pulls things together.
It's true that expansion can inhibit the growth of clusters... but NOT because of a repulsive effect. It is rather because of expansion itself. Things that are moving apart from each other don't cluster together. Even with dark energy, that remains the case.
Something started the universe expanding, to be sure... but that was way back when the universe was a hot "soup" of dense matter and energy. There was, we strongly suspect, a period of "inflation" in the very early universe that kicked off a rapid expansion. But that inflation stopped, and after that the expansion of the universe was not something driven by repulsive effects, but simply the nature of motion everything had been given back then. The major actual force involved is gravity (dark energy only became more significant than gravity after the universe was more than half its present age) and that is an attractive effect to pull clusters together. The main thing gravity has to overcome is NOT a repulsion effect at all, but only the motion itself of material in a universe where everything is moving apart from everything else.
Cheers -- sylas
I think were on the same page as far as the physics goes; I think it's the semantics that we were disagreeing on.
Strictly speaking, I think you're correct, "repulsion" is typically associated with some external force (e.g. electric repulsion). However, in cosmology terms are thrown around that aren't strictly correct (e.g. Hubble friction) but help one intuitively get a feel for a physical process.
Yet, when people talk about repulsion in cosmology, they are usually referring to accelerating expansion (caused by, or at least parametrized by DE). So I think you're right, not because repulsion is technically incorrect (hubble friction is technically incorrect), but because people mostly use "repulsion" to describe accelerating expansion.
Chronos said:
Galactic clusters are gravitationally bound groups of galaxies. ... Superclusters are gravitationally bound groups of galactic clusters.
In other words, it's ad-hoc.
Uh... no. This definition is not ad hoc at all.
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 19 ·
