Gas, Liquids, and solids : Details
  • Context: High School
  • Thread starter Thread starter Kienken333
    Gas Liquids Solids
10 replies · 3K views
Kienken333
From what I know, a liquid is H2O and its atoms are moving constantly. But when it freezes it atoms start to slow down and the liquid is a solid. So the question is there any other way to turn a liquid into a solid?
If the picture doesn't display - please let me know.
Try to read what happens when you increase pressure for a given temperature.
Kienken,
Just to add a bit of information to Borek's phase diagram in case you have any difficulties, the blue part represents all the solid phases of water. Pick any point in the green area, the liquid phase. If you follow a straight vertical line, you are keeping the temperature constant. By going up into this line, you are increasing the pressure without changing the temperature and you can reach the solid phase doing that.
Jan.
So can a gas turn to a solid?
And also thanks for the info.
Another question is that can electricity be positive. Like can it be protons instead of electrons?
Yes. In a metal, the e- are the obvious charge carriers.
However, in a crystal, whether it is metallic, semi-conductor, ionic etc, there are always vacancies. Those are locations where there should be an atom, but it is missing. This allows all the other atoms, which may be effectively positive or negative, to move in the vacancy ("hole") successively. Effectively, it looks like if it was the hole that was moving. In semi-conductors especially, a hole can also be a missing electron.
Another example is cell membranes, including our own nerve cells. The carriers here are ions of various atoms. Some are positive and some are negative. Here is a nice diagram:
http://en.wikipedia.org/wiki/Membrane_potential
Becoming those carriers is somewhat the destiny of the salt in the food we eat. Actual proton currents can also be found in some specialized areas of living organisms.
The current within a battery is also ionic, the carriers can either - and + ions as far as I know
Valence electrons in a conductor (IE a wire) are able to move through the material by jumping from atom to atom i beleive. That is electricity in a nutshell, the movement of those charged particles. I can't see an easy way to create useful electricity using Protons.
Edit: Dr Lots-o'watts post above has good examples of using positive ions to accomplish something. Strictly in the sense of powering electronic devices and transporting electrical power, only electrons are used. The positive ions in a battery are merely a place for the electrons, from negative ions, to deposite themseleves. The electrons run from the negative side of the battery, throughout the circuit, and end up attaching to the positive ions on the positive side of the battery. I guess it all depends on what you mean by your question Kienken, as it is pretty general.
Please do not ask multiple unrelated questions in the same thread. Instead, you should start a new thread with an appropriate title (but first search the forum to make sure your question hasn't already been asked and answered).
Post #8 by Dr L'oW provides a very good answer to your question. If you need to follow up or discuss it further, please ask to have this separate discussion split off into a different thread.
Thanks and I will start this on a new thread.
