Gauge Freedom Quantum Electrodynamics
This discussion centers on the concept of gauge freedom in Quantum Electrodynamics (QED) when analyzing multiple particles in an electromagnetic field. The Hamiltonian for two particles is presented as H=\dfrac{(p_{1}-\frac{e}{c}A)^2}{2m} +\dfrac{(p_{2}-\frac{e}{c}A)^2}{2m} +e \phi, with the condition that \vec{\nabla } \times \vec{A} =\vec{B}. The participants conclude that while one might consider using different gauges for each particle, this approach is incorrect as gauge invariance necessitates a single gauge for the entire system. The equations of motion remain unchanged regardless of the gauge used.
  • Understanding of Quantum Electrodynamics (QED)
  • Familiarity with Hamiltonian mechanics
  • Knowledge of gauge invariance and its implications in electromagnetism
  • Basic concepts of vector potentials and electromagnetic fields
  • Study the implications of gauge invariance in Quantum Electrodynamics
  • Explore the Lorenz gauge and Coulomb gauge conditions in detail
  • Investigate Hamiltonian mechanics for multi-particle systems
  • Learn about the role of vector potentials in electromagnetic theory
Physicists, particularly those specializing in Quantum Electrodynamics, theoretical physicists working on particle interactions, and students studying advanced electromagnetism will benefit from this discussion.
Juan Carlos
It's well known when if we are working on problems related to particles in presence of an electromanetic field, the way we state the problem can be done using the next Hamiltonian:
H=\dfrac{(p-\frac{e}{c}A)^2}{2m} +e \phi where the only condition for A is: \vec{\nabla } \times \vec{A} =\vec{B}
So we have this "gauge freedom" under (of course) the above condition .
What happens when are studying two or more partcles in presence of the electromagnetic field.
Naturally:
H=\dfrac{(p_{1}-\frac{e}{c}A)^2}{2m} +\dfrac{(p_{2}-\frac{e}{c}A)^2}{2m} +e \phi where the only condition for A is: \vec{\nabla } \times \vec{A} =\vec{B}
The question is: can we relax the condition of one unique gauge for all the particles?
Just saying:
can we select two different gauges? obviously with the condition : \vec{\nabla } \times \vec{A} =\vec{B}
I've been working on this, I satetd two different gauges and I can say that there is no difference in terms between the equations of motion having the same gauge. (Hamilton)
In particular I've done the same for the correspoding quantum problem obtainig the heisemberg equations, having the same result: no difference.
I'm interested on the quantum problem because having two different gauges could provoque loosing the symmetry of a Hamiltonian given.
Not sure what you mean by choosing two different gauges/vector potentials for the two particles. If you mean, whether you can use to different vector potentials at the two points which are the locations of the two particles, then the answer is negative. Once you apply a gauge transformation to fix gauge or change to a new gauge, you applying that transformation over all space points including the two locations of the two point charges.
Gauge invariance means that the scalar and vector potentials for the electromagnetic field (or better said the four-vector potential of the electromagnetic field) are only defined up to a four-gradient, i.e., if you have a four-vector potential ##A_{\mu}## then also
$$A_{\mu}'=A_{\mu} + \partial_{\mu} \chi$$
describes the same physical situation, i.e., you get the same field-strength tensor,
$$F_{\mu \nu}=\partial_{\mu} A_{\nu}' - \partial_{\nu} A_{\mu}'=\partial_{\mu} A_{\nu} - \partial_{\nu} A_{\mu} + \partial_{\mu} \partial_{\nu} \chi - \partial_{\nu} \partial_{\mu} \chi = \partial_{\mu} A_{\nu} - \partial_{\nu} A_{\mu}.$$
So you can impose one gauge condition. Depending on the situation you look at, the right choice of gauge can simplify the problem considerably. Usual gauge conditions are the Lorenz gauge
$$\partial_{\mu} A^{\mu}=0$$
and the Coulomb gauge
$$\vec{\nabla} \cdot \vec{A}=0.$$
The equations of motion for your point-particle problem are gauge independent, because only the field components enter (in terms of the Lorentz force, ##q (\vec{E}+\vec{v} \times \vec{B})## (with ##c=1##).
Are you sure about your Hamiltonian for the two (or more) particles?
It's the standard construction.
For Example: Let's suppose we have the magnetic field in the z direction, for example two Landau's gauges:
\vec{A_{1}}=B(-y,0,0) and \vec{A_{2}}=B(0,x,0) where both satisfy \vec{B}=B\vec{k}.
So in particular I could say that my Hamiltonian for the two particle system is:
H=\dfrac{(\vec{p_{1}}-\frac{e}{c}B(-y_{1},0,0))^2}{2m}+\dfrac{(\vec{p_{1}}-\frac{e}{c}B((0,x_2,0))^2}{2m} +e \phi
So I'm using two different gauges for my problem. I'm using it in that sense. What I'd like to emphasise is that the equations of motion are the same in comparison to those obtained when I use only one.
Thank you.
I get your point, is the usual treatment for one particle. But what I'm saying is related to the two particle system, where the question is: Is it correct use two different gauges, one for each particle?
Thank you
No, you should use one gauge for the whole calculation!
and the reason is? I repeat, equations of motion don't change.
  • · Replies 113 ·
13K
  • · Replies 27 ·
  • · Replies 75 ·
10K
