How to Calculate the Heat Released in Magnesium Combustion Reactions?
To calculate the heat released in magnesium combustion reactions, use the formula Q = McΔT, where Q is the heat, M is the mass of the solution, c is the specific heat capacity, and ΔT is the change in temperature. Given the data, the specific heat capacity can be simplified to one calorie per milliliter per degree Celsius. For each reaction, apply the mass of the solution and the temperature change to find the heat released. The calculations should be straightforward with the provided mass and temperature data. This approach will yield the heat released for both magnesium combustion reactions.
blackblanx
Heat of Reaction for the combustion of Magnesium
Data:
A. Mass MgO = 0.7975g Volume 1M HCl = 97.5 ml
Temp.intial = 24.2 C Temp.final = 29.3 C \DeltaT = 5.1 C
B. mass Mg 0.0896g Volume 1M HCl 89.5 ml
Temp. intial = 24.1 c Temp. final = 28.4 c \DeltaT = 4.3 C
With the following data above I need to calculate the heat realsed for each reaction
Need to use Q=Mc \DeltaT also the question tells you to assume one cal of heat is required to change the temperature of one ml of solution one degree Celsius
not sure were to begin
You actually have all of the data you need...
Just turn the last sentence into something more mathematical.
"one calorie of heat is required to change the temperature per 1 degree C per mL of solution"
Is the same as
\frac{Q}{T \cross V}
which describes a specific heat capacity, I believe.
18K
11K
24K
