jonmtkisco said:
Why does the fact that the distance between the dust particles is increasing cause the peculiar velocity of the test particle to decelerate? My understanding is that peculiar velocity decays at the rate of 1/a. This tells me that gravitational deceleration of the expansion causes peculiar velocity to decay more slowly (as a function of time) than if the expansion rate were decelerating less, or not at all.
Jon
Indeed it does, and on the other hand in a Lambda dominated Universe, peculiar velocities decay very quickly. The most straightforward way to see why is to look at the maths, the details are presented in
http://arxiv.org/abs/astro-ph/0609271" paper.
In terms of a handwaving explanation, consider first the empty universe and the tethered galaxy experiment. We set up a distant galaxy such that it has a peculiar velocity towards us that exactly balances the recession velocity away. We then let it go and see what happens.
In the empty universe described in SR co-ordinates the particle simply has no motion with respect to our chosen origin. As per the Milne model, we can postulate massless co-moving particles that have initial velocities proportional to their distance from the origin, this defines the FRW like co-moving co-ordinates. What we see is as time goes by, particles that have slower and slower recession speeds pass our test particle. Since peculiar velocity is defined as the velocity relative to local objects in the Hubble flow the peculiar velocity decays, even though the origin and the test particle have no relative motion at any point.
Now consider what happens when we add matter. It doesn't matter if the universe is flat, closed or open but we will restrict the analysis to an expanding but decelerating epoch (not a collapsing phase of a closed universe). In this case what we see is that the presence of matter will cause all velocities between all particles to decelerate. Relative to the empty universe then, the co-ordinate defining co-moving particles will start to move more slowly past our test particle, i.e. a co-moving particle midway between the origin and the tethered galaxy initially will take longer to move past the tethered galaxy in this decelerating universe than it did in the coasting universe. All of this means that the particles velocity relative to the local Hubble flow remains greater for longer when there is matter in the universe.
In the case of Lambda, the reverse occurs, the co-ordinate defining particles get pushed out more quickly, hence the peculiar velocity decays rapidly.
This is just hand waving though, it's much clearer to go through the maths yourself, and see what terms would change in what way by the addition of matter.
