Geometric Sequence: Find 4th Bounce | Get Steps
The problem involves a ball dropped from a height of 3 feet that bounces back to one-third of the distance it has fallen. Participants are tasked with finding the total distance traveled by the ball when it hits the ground for the fourth time.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss visualizing the problem through graphs and question the distances traveled during each bounce. There are inquiries about whether to add or subtract distances and clarifications on total distance versus net displacement.
Participants are actively exploring the problem, with some providing calculations and others questioning the accuracy of those calculations. There is a mix of interpretations regarding the correct formula for total distance, and various approaches to summing the distances have been suggested.
Some participants express confusion over the notation and constraints of their online homework system, which does not allow for sigma notation. This has led to discussions about alternative ways to express the total distance formula without using summation symbols.
js14
A ball is dropped from a height of 3 ft. The elasticity of the ball is such that it always bounces up one-third the distance it has fallen.
(a) Find the total distance the ball has traveled at the instant it hits the ground the fourth time. (Enter your answer as an improper fraction.) Can someone show me the steps oon how to do this?
You could start by drawing a graph of the ball's altitude vs time (does not need to be exact with regard to time) to better visualize what is going on.
How far would the ball drop the first time?
How far would it come up?
How far would it fall the second time?
How far would it fall the third time?
How far would it fall the fourth time?
What is the sum of all these distances?
so am I subtracting every time the ball bounces?
Not subtracting, but adding.
If you drive your car for instance forward and backward and forward and backward, the distance meter will keep going up.
I think they are looking for total distance, not net displacement.
Thanks for making me have to drive around the block backwards. I did not believe you, having watched Ferris Bueller about infinity times, but now I do--you are correct (for an '08 Jetta, anyway).
:smile:
I watched Ferris Bueller too!
[edit]However, when the car went down, instead of forward or backward, I think the distance meter may have stopped going up :)[/edit]
For example, the first bounce will come up to a height of 1 ft. When the ball falls back down and hits the ground for the second time, it will have traveled (3+1 +1) ft = 5 ft. Then the ball will rise again up to a third of a foot, and fall again. So the total distance once the ball has hit the ground for the third time is (3 + 1 + 1 + 1/3 + 1/3)ft. Continue this process until the ball has hit the ground for the fourth time.
So would it be 3+1+1+1+1/3+1/3+1/3?
not quite. Why is there three 1's in your sum? And why is the last term 1/3?
What is a third of 1/3? Try to visualize this. Draw a diagram.
Down 3 feet.
Up 1/3 of that, 1 foot.
Down 1 foot. (total for this "up-down", 2 feet)
Up 1/3 of that, 1/3 foot
Down 1/3 foot. (total for this "up-down", 2/3 feet)
Up 1/3 or that, 1/9 foot
Down 1/9 foot. (total for this "up-down", 2/9 feet)
etc. (Why did you stop after only a few bounces- a geometric series can be summed for an infinite number of terms.)
(Ah, because the problem said "at the instant it hits the ground the fourth time", of course.!)
Here is the sequence if you are interested :P
[tex]3 + \sum_{n=0}^{2}{\frac{2}{3^n}[/tex]
Or perhaps a more insightful version of this is:
[tex]3 + \sum_{n=0}^{2}\left({\frac{1}{3^n} + \frac{1}{3^n}}\right)[/tex]
Or for an arbitrary number of bounces, the distance after the ball has hit the ground for the [tex]B^{th}[/tex] time is
[tex]3 + \sum_{n=0}^{B-2}\left({\frac{1}{3^n} + \frac{1}{3^n}}\right)[/tex]
Does this work? d1=3
second time d2=3*K=1
Third time d3=1*k=1/3
Forth time d4=K(1/3)=1/9
Now adding up d1+d2+d3+d4, we get the total distance
d=40/9
ok the answer is 53/9!
d=40/9
Nope. Did you not read HallsofIvy's post?
HallsofIvy said:
Down 3 feet.
EDIT: Re post #15: Now you got it!
I got that part of the answer but now it asks this: Find a formula for the total distance the ball has traveled at the instant it hits the ground the nth time. I solved the problem like in the above problems. Is 9-(1/3)^n-3 the right formula?
You mean this?
[tex]9 - \left( \frac{1}{3} \right)^n - 3[/tex]
If so, then that is wrong.
no 9-(1/3) raised to the n-3.
this is not right.. if summed from n=1 it gives
[tex]9 - 6 - 3 - ...[/tex]
it will end up being a negative distance...
The correct sequence was shown in an earlier post.
Yea I saw the formula with the sigma notation but my online homework dosent have sigma signs so their must be another way to write the sequence using only fractions...?
let G.S be a Geometric Sequence where a=3 r=1/3
S4=(3*((1/3)4-1))/((1/3)-1)=(40/9)
But 40/9 is not the correct answer
I guess no one knows the correct answer...?
[tex]3+1+1+1/3+1/3+1/9+1/9[/tex]
The correct answer has been shown several times in this thread.
and the sequence goes, (after starting at 3)
[tex]\frac{2}{3^n}[/tex]
starting from n = 0
But the formula for the total distance must be a summation! A sequence is just a lot of numbers...
Once the ball has hit the ground for the nth time, it will have traveled a distance D
[tex]D = 3 + \sum_{i=0}^{n-2}{\frac{2}{3^i}[/tex]
I understand that answer its definitely correct, however my online homework has no sigma signs(meaning i can enter an answer like the one you show) so i was just suggesting that there must be a different way to write the equation. For example there is a similar question in my precalc book with the being dropped from 9 ft instead of 3ft and you were supposed to find the 5th bounce not the 4th. anyway the answer to the first part of the question was 17 (8/9) written as a mixed number. The equation to the problem(which is what I am trying to find out for this problem) was 18-(1/3)^n-3. no sigma notation. So what I am trying to explain is that i have to figure out how to put the equation to my problem into something similar to that. No sigma.
Please, please, please, be precise with your notation. It's quite annoying when parentheses aren't used, because again, what you wrote looks like
[tex]18 - \left( \frac{1}{3} \right)^n - 3[/tex]
to me. And based on your previous post, I suspect you meant
[tex]18 - \left( \frac{1}{3} \right)^{n - 3}[/tex]
. You should really learn LaTex. If you cannot, at least for goodness sake use parentheses, like this:
18-(1/3)^(n-3)
Sorry if I sound cross. This is one of my pet peeves. Anyway, back to your question...
If you want to write out the sum of a finite number of terms in a geometric sequence, well, kiko_milzo, hinted at this, even though the answer wasn't correct to your original problem:
You'll need the sum of the first n terms of a geometric series formula:
[tex]a + ar + ar^2 + ... + ar^{n-1} = \frac{a(1 - r^n)}{1 - r}[/tex]
heres an idea.
Evaluate the sum that I provided above for different values of n.
You should find a series:
[tex]3, 5, 17/3, 53/9, 161/27, 485/81,[/tex]
etc..
Do you see a pattern?
Perhaps its better to write these as mixed numbers. Then the pattern should be quite clear.
